I am building a prototype that will use the nrf52840, with limited space. Would making a small pcb antenna or using a chip antenna be better and what is the setup needed for the antenna. (capacitors and inductors)
Hi Jacob,
the smallest PCB trace antenna is going to be a meander antenna, you use the layout of the nRF51 Dongle as a reference, here is the link. In terms of components you usually just need a shunt capacitor and then you adjust the length of the antenna in order to tune it.
If a PCB meander antenna is too big, then your only option is to go for a chip antenna. You will then need a full PI network, two shunt and one series components in order to properly tune the antenna. You can use the Nordic Thingy:52 layout as a reference, here is the link.
Thus, it boils down to cost and how space you have on your PCB for the antenna.
Best regards
Bjørn
Hi Jacob,
Best regards
Bjørn
Links are unavailable...
Hi Matthew,
the links should be fixed now.
-Bjørn
