Hello:
Why Bluetooth Go to system-off mode, sd_power_ramon_set can not be stored. In D: \ RAM save nrf51_sdk_v5_2_0_39364 \ nrf51822 \ Board \ nrf6310 \ s110 \ ble_app_rscs \ arm program。I devzone.nordicsemi.com/.../ram-and-off-mode, where the test is no problem, but the test will not work in the Bluetooth inside,this is why?
Here is my code:
1.0 Define a test:
static uint8_t test[3] __attribute__( ( section( "NoInit"), zero_init) );
2.0 In the wake main:
// Initialize
leds_init();
if (test[0]== 0X31)
nrf_gpio_pin_clear(LED_2);
nrf_gpio_pin_set(LED_3);
nrf_gpio_pin_set(LED_4);
nrf_gpio_pin_set(LED_2);
nrf_gpio_pin_clear(LED_3);
nrf_gpio_pin_clear(LED_4);
buttons_init();
ble_stack_init();
bond_manager_init();
timers_init();
gap_params_init();
advertising_init();
services_init();
sensor_sim_init();
conn_params_init();
sec_params_init();
// Start execution
application_timers_start();
advertising_start();
// Enter main loop
for (;;)
power_manage();
3.0 This is my code into the system-off mode:
test[0]=0X31;
test[1]=0X32;
test[2]=0X33;
// sd_power_ramon_clr (POWER_RAMON_OFFRAM0_Msk | POWER_RAMON_OFFRAM1_Msk);
sd_power_ramon_set(POWER_RAMON_OFFRAM0_Msk | POWER_RAMON_OFFRAM1_Msk);
// Go to system-off mode (this function will not return; wakeup will cause a reset)
When I wake up when the key value is not saved TEST do not know where is the problem? I sd_power_ramon_set function here plus sd_power_ramon_clr (POWER_RAMON_OFFRAM0_Msk | POWER_RAMON_OFFRAM1_Msk), the value of test is not clear。
