Can we interface a smbus based sensor with NRF51 or NRF52? The only difference between smbus and TWI is the minimum speed requirement which is 10Khz if I am correct.
There are some more differences between the bus specifications, for instance does the SMBus specify a maximum frequency of 100 kHz.
Nomally it is no problem to interface SMBus devices using TWI, as long as you keep the speed at 100 kHz.
Jørgen
Thanks Jorgen
Thanks Jorgen
