In order to prevent communication from middle-man attack, I append the signature after ECDH publickey. However, though I get the correct share secret by ECDH, I fail in verifying the micro ecc signature in Android studio, and 52832 also fails in verify android signature. Here's my test codes:
private void showsignature() {
KeyPair keyPair = ECC.CreateKeyPair();
ECPublicKey ecPublicKey = (ECPublicKey) keyPair.getPublic();
ECPrivateKey ecPrivateKey = (ECPrivateKey) keyPair.getPrivate();
byte[] sk = ECC.ECPrivateKey2ByteArray(ecPrivateKey);
byte[] pk = ECC.ECPublicKey2ByteArray(ecPublicKey);
byte[] ss = ECC.ShareSecret(ecPublicKey, ecPrivateKey);
byte[] msg = "hello".getBytes();
byte[] sign = ECC.CreateSignature(msg, ecPrivateKey);
System.out.println("sk:");
System.out.println(Hex2Str(sk));
System.out.println("pk:");
System.out.println(Hex2Str(pk));
System.out.println("ss:");
System.out.println(Hex2Str(ss));
System.out.println("sign:");
System.out.println(Hex2Str(sign));
if (ECC.VerifySignature(ecPublicKey, msg, sign)) {
System.out.println("verify pass");
I write a public class (ECC) to deal with the details about the format converting from micro ecc raw byte array to Android format.Because Android and nrf52832 can get the same share secret, so I do belive there's no bug in converting. Aftern I get some data created by the above Android function, I put the data to nrf52832 to verify the signature.
static void test(void)
uint8_t sk[] ={
0x81,0x37,0x42,0xA8,0x20,0xEE,0x40,0x04,
0x6B,0xEF,0xB1,0x78,0x65,0x9F,0xE3,0x8A,
0x35,0x35,0xA4,0x0C,0xB7,0xFC,0x16,0xE4,
0xE0,0x9F,0xD6,0x24,0xE3,0x24,0x97,0x56};
uint8_t pk[] = {
0xDF,0xA7,0x14,0x97,0xDB,0x37,0x22,0xA3,
0x82,0xE1,0x6D,0x2A,0xE1,0x60,0x82,0x85,
0xB9,0x9A,0x10,0x40,0x27,0xC4,0x2E,0xCB,
0xFB,0xFB,0x6D,0x13,0x62,0xD4,0x5F,0x17,
0x26,0xE1,0x2E,0x34,0x0F,0xA1,0x5A,0x57,
0x5B,0x2F,0x28,0x69,0xCA,0x76,0x9E,0x8C,
0x7A,0xBD,0x60,0x05,0xA8,0xD3,0x16,0xC9,
0x06,0xC4,0x05,0x3E,0x95,0xD4,0x98,0x5F};
uint8_t sign[]={
0x93,0xD3,0xB7,
0x9C,0x8C,0x05,0xED,0x0C,0xF0,0x7D,0xF4,
0x4C,0xFB,0x9B,0x89,0x2D,0x3E,0xAB,0xF9,
0xDE,0x11,0x72,0x05,0xB2,0xBD,0x71,0x03,
0x5E,0x63,0x81,0x0C,0xAC,
0x0F,
0xC9,0xAB,0x1F,0x55,0xA4,0x25,0x8D,0x50,
0x81,0xF0,0xFE,0x17,0xDC,0x19,0x9A,0x40,
0x45,0x8C,0x28,0x43,0xAA,0x23,0xA6,0xB2,
0x6F,0x38,0xCC,0xC2,0x2D,0x31,0x89};
char *msg="hello";
uint8_t ss[32];
ChangeENDIAN(sk,32);
ChangeENDIAN(pk,32);
ChangeENDIAN(&pk[32],32);
uint8_t hash[32];
Hash(msg,5,hash);//SHA256
ChangeENDIAN(hash,32);
if (ecc_p256_verify(pk,hash,32,sign)==NRF_SUCCESS)
NRF_LOG_INFO("PASS\n");
NRF_LOG_INFO("FAIL\n");
NRF_LOG_FLUSH();
} Because the ENDIAN not the same,so change the endian before micro ecc use Android data.
static void ChangeENDIAN(uint8_t * msg, uint8_t length) {
uint8_t buffer;
for (uint8_t i=0;i<length/2;i++)
buffer=msg[i];
msg[i]=msg[length-1-i];
msg[length-1-i]=buffer;
I did everything I can do , but still failed in the verifying, why? Here's the total data from Android:
sk:
0x81,0x37,0x42,0xA8,0x20,0xEE,0x40,0x04, 0x6B,0xEF,0xB1,0x78,0x65,0x9F,0xE3,0x8A, 0x35,0x35,0xA4,0x0C,0xB7,0xFC,0x16,0xE4, 0xE0,0x9F,0xD6,0x24,0xE3,0x24,0x97,0x56,
pk:
0xDF,0xA7,0x14,0x97,0xDB,0x37,0x22,0xA3, 0x82,0xE1,0x6D,0x2A,0xE1,0x60,0x82,0x85, 0xB9,0x9A,0x10,0x40,0x27,0xC4,0x2E,0xCB, 0xFB,0xFB,0x6D,0x13,0x62,0xD4,0x5F,0x17, 0x26,0xE1,0x2E,0x34,0x0F,0xA1,0x5A,0x57, 0x5B,0x2F,0x28,0x69,0xCA,0x76,0x9E,0x8C, 0x7A,0xBD,0x60,0x05,0xA8,0xD3,0x16,0xC9, 0x06,0xC4,0x05,0x3E,0x95,0xD4,0x98,0x5F,
ss:
0x6B,0x7D,0x7A,0x27,0x8B,0x16,0xE7,0xEC, 0x67,0x0C,0x9C,0x84,0xE5,0x72,0x1A,0x04, 0x5E,0x60,0xE5,0xA3,0xAB,0xDF,0x75,0xE1, 0x49,0xB1,0x6F,0x21,0xAC,0xA8,0x22,0x61,
sign:
0x30,0x45,0x02,0x21,0x00,0x93,0xD3,0xB7, 0x9C,0x8C,0x05,0xED,0x0C,0xF0,0x7D,0xF4, 0x4C,0xFB,0x9B,0x89,0x2D,0x3E,0xAB,0xF9, 0xDE,0x11,0x72,0x05,0xB2,0xBD,0x71,0x03, 0x5E,0x63,0x81,0x0C,0xAC,0x02,0x20,0x0F, 0xC9,0xAB,0x1F,0x55,0xA4,0x25,0x8D,0x50, 0x81,0xF0,0xFE,0x17,0xDC,0x19,0x9A,0x40, 0x45,0x8C,0x28,0x43,0xAA,0x23,0xA6,0xB2, 0x6F,0x38,0xCC,0xC2,0x2D,0x31,0x89,
Because android' signature is in DER format, so it's not in 64bytes. nrf52832 supported by sdk12.2/keil 5.23
