Issue Resolving DNS in Border Router
I'm following the tutorial in the NRF52840 SDK on setting up a Thread Border Router here and I've run into some issues during testing. For one, I'm trying to resolve ipv4.google.com on the dev kit running the CLI, and in response I get Error 28: ResponseTimeout. Looking into the system log for OpenWRT, the dnsmasq service fails to create a listening socket as port 53 is in use. As a result, the service doesn't start. If I try to ping 8.8.8.8 directly from the OpenWRT command line, I get a response, but pinging google.com returns an unknown host or a bad address error (depending on if I use the command line interface or the web interface).
I'd really appreciate any help you folks can provide and will update with any additional information requested. Thanks!
  • Hi TravisFS,
    Great that you got it working on the work network!
    I have spoken to our Thread developers about your issues, and have the following comments:
    1. The dnsmasq error in the OpenWRT log is normal and can be ignored.
    2. Failing DNS resolve on the OpenWRT is expected, as this is not a needed feature in the BR.
    3. Successfull pinging of 8.8.8.8 from OpenWRT is expected, as it have IPv4 connectivity.
    The failed DNS resolve on the Thread node is not expected. Since you say you only have IPv4 connectivity, did you use the DNS64 command as described in the documentation:
    If the host does not have IPv6 connectivity, a Thread device may still connect with a IPv4 cloud utilizing the NAT64 and DNS64 protocols. To obtain a a translated IPv6 address, you must specify the DNS resolver fd00:0064:0123:4567::1 which is running on the Thread Border Router, as shown below:
    > dns resolve ipv4.google.com
    > DNS response for ipv4.google.com - Error 25
    > dns resolve ipv4.google.com fd00:0064:0123:4567::1
    > DNS response for ipv4.google.com - [fd00:64:123:4567:0:0:acd9:14ae] TTL: 300
    > ping fd00:64:123:4567:0:0:acd9:14ae
    > 8 bytes from fd00:64:123:4567:0:0:acd9:14ae: icmp_seq=3 hlim=55 time=42ms
    Error 25 indicates that there is no IPv6 address returned as the ipv4.google.com does not have any.
    If you still is not able to resolve the DNS, please message me (don't post in public) output from ifconfig on OpenWRT and output of ipaddr on Thread CLI node.
    Jørgen
  • This is maybe interesting. How did I manage to clear the MAC address (ID=13 has the issue)???
    > router table
    | ID | RLOC16 | Next Hop | Path Cost | LQI In | LQI Out | Age | Extended MAC                                              |
    | 12 | 0x3000 |       42 |         1 |      3 |       3 |  21 | something...........                                          |
    | 13 | 0x3400 |       13 |         0 |      0 |       0 |  87 | 0000000000000000                                          |
    | 26 | 0x6800 |       42 |         1 |      3 |       3 |   5 | something...........                                          |
    | 42 | 0xa800 |       12 |         1 |      3 |       3 |   4 | something...........                                         |
    > router table
