[nRF8001] Bond timeout less than specified in datasheet
I'm trying to use the Bond ACI command on my nRF8001, but I'm having trouble using it as per the datasheet.
When I set the Timeout parameter to more than 30 (0x001E), the Bond command responds with a CommandResponseEvent saying the parameters are invalid, though the datasheet says the value for the Timeout parameter can be 1-180 (0x00B4), just like for the Connect command, for which the values specified work fine. The bounds for the AdvInterval parameter in the datasheet work correctly as well.
Is this a known issue I'm not aware of, did I miss a configuration parameter in nRFgo Studio, or is it something else entirely?
