Hi everyone,
I was wondering if the nRF52840 DK will have NCP OpenThread support for wpantund Linux (other than Raspberry Pi) or if it already exists. I flashed the nRF52840 DK with the NCP binary from the 0.10.0 Thread SDK and I built the wpantund on Ubuntu 16.04. I used the following wpantund configuration for the communication between the NCP and the host PC:
Config:TUN:InterfaceName wpan0 Config:NCP:SocketPath "serial:/dev/ttyS0,raw,b115200,crtscts=0" Config:NCP:DriverName spinel
The program was able to establish the serial connection but the initialization failed with these errors:
wpantund[2316]: Initializing NCP wpantund[2316]: NCP is now BUSY. wpantund[2316]: [->NCP] CMD_PROP_VALUE_GET(PROP_PROTOCOL_VERSION) tid:1 wpantund[2316]: ↳ 810201 wpantund[2316]: SpinelNCPInstance-Protothreads.cpp:440: Requirement Failed (IS_EVENT_FROM_NCP(event) && GetInstance(this)->mInboundHeader == mLastHeader) wpantund[2316]: Resetting and trying again... (retry 1) wpantund[2316]: [->NCP] CMD_RESET tid:2 wpantund[2316]: ↳ 8201 wpantund[2316]: SpinelNCPInstance-Protothreads.cpp:430: Requirement Failed (event == EVENT_NCP_RESET) wpantund[2316]: Resetting and trying again... (retry 2) wpantund[2316]: SpinelNCPInstance-Protothreads.cpp:430: Requirement Failed (event == EVENT_NCP_RESET) wpantund[2316]: Resetting and trying again... (retry 3) wpantund[2316]: [->NCP] CMD_RESET tid:3 wpantund[2316]: ↳ 8301 wpantund[2316]: SpinelNCPInstance-Protothreads.cpp:430: Requirement Failed (event == EVENT_NCP_RESET) wpantund[2316]: The NCP is misbehaving: Repeatedly unable to initialize NCP. Entering fault state. wpantund[2316]: State change: "uninitialized" -> "uninitialized:fault"
Thank you.
It seems that your configuration is wrong. Usually USB CDC class, used for serial over USB communication, is under "/dev/ttyACM0", NOT "/dev/ttyS0".
Best regards, Krzysztof …
Best regards, Krzysztof Loska
I have exactly the same problem but on my RaspPi.
wpantund[1470]: Starting wpantund 0.08.00d (Aug 4 2017 14:47:03) . . . wpantund[1470]: BUILD_VERSION = f26ee8f wpantund[1470]: Configuration file "/etc/wpantund.conf" read. wpantund[1470]: Ready. Using DBUS bus ":1.180" wpantund[1470]: Running as root without dropping privileges! wpantund[1470]: SpinelNCPInstance-Protothreads.cpp:412: Requirement Failed (IS_EVENT_FROM_NCP(event) && GetInstance(this)->mInboundHeader == mLastHeader) wpantund[1470]: Resetting and trying again... (retry 1) wpantund[1470]: SpinelNCPInstance-Protothreads.cpp:402: Requirement Failed (event == EVENT_NCP_RESET) wpantund[1470]: Resetting and trying again... (retry 2) wpantund[1470]: SpinelNCPInstance-Protothreads.cpp:402: Requirement Failed (event == EVENT_NCP_RESET) wpantund[1470]: Resetting and trying again... (retry 3) wpantund[1470]: SpinelNCPInstance-Protothreads.cpp:402: Requirement Failed (event == EVENT_NCP_RESET) wpantund[1470]: The NCP is misbehaving: Repeatedly unable to initialize NCP. Entering fault state. wpantund[1470]: State change: "uninitialized" -> "uninitialized:fault"
Im trying to run Nordic RF52840 kit (NCP example) with RbPi and github.com/.../borderrouter as it has a Border Router Agent with support for external commissioner. It seems that there are some problems with wpantund.
I have Config:NCP:SocketPath "serial:/dev/ttyACM0,raw,b115200,crtscts=1" in my /etc/wpantund.conf and I have such device in /dev. Any ideas what can go wrong?
PS. openthread/borderrouter says it is based on Thread 1.1.1 spec. I couldn't find such info for Nordic examples. Is it compatible?
In general, our NCP should be compatible with OpenThread's boarder router. Do you see the ttyACM0 device in /dev? If not, you might not have loaded the kernel module cdc_acm. You should also check the dmesg log while connecting the NCP.
ttyACM0
/dev
cdc_acm
dmesg
As I am at too earlier a stage to offer a solution, here is my comment on this issue. I am using a Debian 9 host with the binary ot-ncp-fth.hex created from the current openthread master from github, loaded onto the nRF52840. wpantund was working ok until I did something "wrong" while using wpanctl. After that, I would get the error as described above, even after resetting, disconnecting/reconnecting re-powering etc the nRF52840 board. ONLY AFTER REPROGRAMMING THE NRF52840 BOARD did the behavior return to normal. This would imply that some setting was made to Non-volatile memory of the nRF52840 board.
