How to compile sample project from SDK for nRF52 successfully after importing it to IAR workbench
Right now I am facing a problem as mentioned below: I downloaded nRF52 SDK version 12.3.0. It contains lot of example code. I found .eww file in each example project folder. I was able to open the project by double clicking on the .eww file. In IAR IDE, under workspace, it lists down the project name and associated files. It lists all the included header files as well. However, the problem arises when I try to compile the project. It gives lot of errors which are kind of dependency errors. I am not sure, how to readily use the given example code, compile them and run it on target board. Following are some of the errors that I see on compiling any of the example project:
Error[Pe223]: function "__REV" declared implicitly E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\libraries\util\app_util.h 908
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 143
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 143
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 158
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 158
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 174
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 174
Error[Pe012]: parsing restarts here after previous syntax error E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 180
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 190
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 190
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 201
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 201
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 208
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 208
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 216
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 216
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 224
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 224
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 235
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 235
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 246
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 246
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 255
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 255
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 264
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 264
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 274
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 274
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 284
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 284
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 298
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 298
Error[Pe757]: variable "__STATIC_INLINE" is not a type name E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 310
Error[Pe101]: "uint32_t" has already been declared in the current scope (at line 30 of "C:\Program Files (x86)\IAR  E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 310
Systems\Embedded Workbench 8.0\arm\inc\c\stdint.h")
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 310
Error[Pe757]: variable "__STATIC_INLINE" is not a type name E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 319
Error[Pe101]: "uint32_t" has already been declared in the current scope (at line 30 of "C:\Program Files (x86)\IAR  E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 319
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 319
Error[Pe757]: variable "__STATIC_INLINE" is not a type name E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 328
Error[Pe101]: "nrf_gpio_pin_sense_t" has already been declared in the current scope (at line 127) E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 328
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 328
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 337
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 337
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 346
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 346
Error[Pe077]: this declaration has no storage class or type specifier E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 355
Error[Pe065]: expected a ";" E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 355
Error[Pe757]: variable "__STATIC_INLINE" is not a type name E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 364
Error[Pe101]: "uint32_t" has already been declared in the current scope (at line 30 of "C:\Program Files (x86)\IAR  E:\<Path To SDK>\nRF5_SDK_12.3.0_d7731ad\nRF5_SDK_12.3.0_d7731ad\components\drivers_nrf\hal\nrf_gpio.h 364
