Secure DFU, Should you use fstorage or nrf_dfu_flash
Within a buttonless DFU application should nrf_dfu_flash or fstorage be used to erase and write to flash?
SDK 13.0.0 - Soft device s132_nrf52_4.0.2_softdevice running on a nRF52832.
I want to store device specific information (like Serial Number) in flash that the DFU update will not erase. I am following the default DFU memory layout and want to place this information at the end of the application area. DFU_APP_DATA_RESERVED is set to CODE_PAGE_SIZE * 3. My understanding is that this setting will cause the DFU to no erase the last 3 pages of the application area.
    That configuration instructs the bootloader to not erase some flash pages which are used by the Peer Manager to store bond information. Thus, the application can retain bond data after a DFU. If you write to that area using fstorage you might end up corrupting the fds data.
    In short:
    • If you don't use Peer Manager, you can use that area as you wish.
    • If use Peer Manager, increase DFU_APP_DATA_RESERVED to include more one flash page and write your data there.
    In short:
