NRF51822 sdk 10.0After binding the connection fails
Hello, I now is in a problem.My equipment set up matching binding but after binding equipment connection will connection failure.If it is not binding, it can be the connection is successful. Could you tell me how to solve this problem this I should be. The following is part of the program
void init_keyset(void) {
keyset.keys_periph.p_enc_key = &my_enc_key;
keyset.keys_periph.p_id_key = NULL;
keyset.keys_periph.p_sign_key = NULL;
keyset.keys_central.p_enc_key = &my_enc_key_center;
keyset.keys_central.p_id_key = NULL;
keyset.keys_central.p_sign_key = NULL;
static void resp_pair_request() {
uint32_t err_code; sec_params.bond = SEC_PARAM_BOND;
sec_params.mitm = SEC_PARAM_MITM;
sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_params.oob = SEC_PARAM_OOB;
sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_params.kdist_central.enc = 1;
sec_params.kdist_central.id = 0;
sec_params.kdist_central.sign = 0;
sec_params.kdist_periph.enc = 1;
sec_params.kdist_periph.id = 0;
sec_params.kdist_periph.sign = 0;
err_code= sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,&keyset); APP_ERROR_CHECK(err_code); }
static void on_ble_evt(ble_evt_t * p_ble_evt) {
uint32_t err_code;
    case BLE_GAP_EVT_CONNECTED:
        LEDS_ON(CONNECTED_LED_PIN);
        LEDS_OFF(ADVERTISING_LED_PIN);
       init_keyset();
        err_code = app_button_enable();
        LEDS_OFF(CONNECTED_LED_PIN);
        err_code = app_button_disable();
        advertising_start();
        // Pairing not supported
        resp_pair_request();
        //APP_ERROR_CHECK(err_code);
	case BLE_GAP_EVT_PASSKEY_DISPLAY:
		 printf("show passkey: ");
        for ( int i = 0; i < 6; i++)
 {        while(app_uart_put(p_ble_evt->evt.gap_evt.params.\
        passkey_display.passkey[i]) != NRF_SUCCESS);
    case BLE_GAP_EVT_AUTH_STATUS:
	    if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
         printf("pair success\r\n");
        sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
		case BLE_GAP_EVT_SEC_INFO_REQUEST:
		 err_code = sd_ble_gap_sec_info_reply(m_conn_handle, &(my_enc_key.enc_info), NULL, NULL);
