Set a button as an interrupt source
Hi, I'm trying to set a button as an interrupt source. I wrote this code:
void Init(void){
	pwrmng_MainStatus = PWRMNG_STS_STARTUP;
	//LED
	#ifdef DEBUG_LED
	nrf_gpio_cfg_output(LED_R);
	nrf_gpio_cfg_output(LED_G);
	LED_G_TURN_OFF();
	LED_R_TURN_OFF();
	//Interfaccia
	nrf_gpio_cfg_input(INTERFACE, NRF_GPIO_PIN_NOPULL);
	//Startup Moduli
	timers_init();
	ble_stack_init();
	gap_params_init();
	conn_params_init();
	//Bottone
	//button_init();
	IRQ_init();
uint32_t IRQ_init(void)
    uint32_t err_code = NRF_SUCCESS;
    nrf_drv_gpiote_in_config_t config_pin = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
    if (!nrf_drv_gpiote_is_init())
        if (err_code != NRF_SUCCESS)
            return err_code;
    config_pin.pull = NRF_GPIO_PIN_NOPULL;
    err_code = nrf_drv_gpiote_in_init(BUTTON_0, &config_pin, button_evt_handler);
        return err_code;
    nrf_drv_gpiote_in_event_enable(BUTTON_0, true);
    return(err_code);
void button_evt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	pwrmng_MainStatus = PWRMNG_STS_SHUTDOWN;
int main(void){
	Init();
	for(;;){/* CODE */}
err_code is 0x00 so I think that the initialization of BUTTON_0 succeeded. The problem is that I never enter button_evt_handler() pushing the button. BUTTON_0 is PIN21 in my application and I can see PIN21 changing state going to DEBUGGING->PERIPHERALS->GPIO. What's wrong with my code? I'm using softdevice S130 and nRF51822. Thanks!
