failed to upload ble_app_uart with dfu
Hi everybody.
I am making a firmware based on ble_app_uart example (PCA10028 NRF51422, Softdevice S110, NRF51 SDK9.0). In this firmware, I insert dfu part (follow by this instruction ) to support upload firmware via OTA(by nrfConnect android app). I upload successful at the first time (the MCU already has Softdevice and bootloader in memory). However, when I upload again it is failed and the android app show a message: upload failed dfu service disconnected.
Could you please tell me how to solve this problem?
Sorry because my English is not good. Thank you very much.
UPDATE: I put the log file for each test case:
  • Step 1: I upload Softdevice and bootloader to MCU, then I use nrfconnect to upload my ble app, the result is successfull and the log file is here
  • Step 2: After upload my ble app, I connect and re-upload my ble app (the ble app version is 0xFFFFFFFF) the result is failed and the log file is here
  • Step 3: I erase the memory of MCU then upload Softdevice and bootloader same as step 1. After that, I upload the sample dfu file (dfu_test_hrm_s110.zip). The result is successfull and here is log file.
  • Step 4: I connect and upload dfu_test_hrm_s110.zip second time, the result is successfull and this is log file.
  • FormerMember
    0 FormerMember
    Bạn có phải người Việt Nam không Minh , tôi cũng đang tìm hiểu về BLE , tôi dùng NRF52832 . Chúng ta có thể giao lưu giúp đỡ nhau :)
  • Chào các bạn, mình cũng là người Việt Nam đây. Rất hân hạnh được giúp các bạn :)
    @Minh: có chắc cái này "However, when I upload again it is failed and the android app show a message: upload failed dfu service disconnected. " match với cái log trên hình không ? Vì cái trên hình là log đã update thành công và trigger activate and reset.
    Minh có thể test bằng example experimental_ble_app_buttonless_dfu để xem có thể update được nhiều lần không. Ngoài ra thử thêm bằng nRFToolbox.
  • Dạ trường hợp trên là em thêm dfu service vào code của ble_app_uart(dựa vào code của ble_app_hrs) rồi sau đó test dfu bằng cách upload nhiều lần nhưng lỗi như trên lại xuất hiện. Khi em test với chương trình có chứa dfu mẫu(ble_app_hrs) thì việc update nhiều lần không vấn đề gì. Em thắc mắc ở chỗ đó vì khi dùng nrfconnect kết nối với code của em thì dfu_service có xuất cùng với nus_service.
  • Xin bạn up thêm 1 cái log nữa (tốt nhất là xuất ra file, chọn level DEBUG chứ ko chỉ INFO), như đã nói ở trên cái screenshot bên trên cho thấy quá trình DFU đã hoàn tất , đã activate và reset. Như vậy của bạn có chạy đến 100% trước khi bị lỗi không ?
    Nếu bạn có thể gửi về sniffer trace của quá trình (lần thứ nhất thành công, lần thứ 2 bị lỗi) thì sẽ dễ để khảo sát hơn.
  • Em xin lỗi vì mạch em để ở cty nên tuần trước em không trả lời ngay được, hôm nay em có làm lại theo kịch bản trước, dưới đây là các file log em có lưu lại ạ:
    B1: Ban đầu MCU chỉ có softdevice và bootloader, em upload app của em và thu dc file log này ạ
    B2. Sau khi hoàn thành B1, em kết nối với chương trình và upload lại lần 2, thu được file log này ạ
    B3. xóa toàn bộ code trong memory, upload sofdevice và bootloader, quay lại bước 1 nhưng upload file dfu mẫu (dfu_test_hrm_s110.zip) và thu được file log này.
    B4. Kết nối và thực hiện upload file dfu_test_hrm_s110.zip lần 2 và thu dc file log này.
    Trong kịch bản trên thì thực hiện lần 2 với file dfu mẫu thành công nhưng với chương trình của em thì lỗi ạ.
