Usage Fault in App Scheduler
I'm using and NRF52 with S132 and SDK13.0. I'm using Keil as my IDE.
My application acts as a central for smart phones to connect to and also acts as a peripheral to conect to multiple other devices.
Currently my app works well with up to 2 smart phones configured and connected, and up to 4 of the external devices connected simultaneously.
I am currently trying to add the capability for more smart phones to connect to my device. Unfortunately, when I configure my device to be able to connect to more than 2 smart phones, it starts receiving usage faults. My knowledge of debugging this is somewhat limited so, the method i use and conclusion I've drawn may be wrong. I'd love some help to figure it out.
I've been using this app note to help me.
The image below shows the registers, fault reports, and location (i believe this is correct) of the fault. image description
here's my process for coming to that point
  1. Link Register is 0xFFFFFFE9, bit 2 is zero so, The main statck is used.
  2. The main stack pointer (MSP) points to 0x2000E6E8
  3. So looking at the contents of memory at 0x2000E6E8, I can see the previous execution context
  4. The Link register of the previous execution context is 0x022EBB, minus 1 because it is in thumb mode, gives 0x022EBA. This shows where the code is returning to and this is shown in the disassembly window as m_queue_start_index = next_index(m_queue_start_index); So think it's coming back from event_handler(p_event_data, event_data_size);
  5. The Fault Report window shows it is a usage fault with INVSTATE set which means
the processor has attempted to execute an instruction that makes illegal use of the Execution Program Status Register (EPSR). When this bit is set, the PC value stacked for the exception return points to the instruction that attempted the illegal use of the EPSR. Potential reasons: a) Loading a branch target address to PC with LSB=0. b) Stacked PSR corrupted during exception or interrupt handling. c) Vector table contains a vector address with LSB=0.
So I think that the error is happening in event_handler(p_event_data, event_data_size) in app_scheduler.c but, when I put some debug statements around my app_scheduler event statement, i always see it start and finish. I've also check my appsceduler queue usage using app_sched_queue_utilization_get but never see more than a 40% utilisation
It may not be related, but I'm also occasionally seeing a busfault with IBUSSERR set and I get the same LR value of the previous execution context which is 0x022EBB, minus 1 because it is in thumb mode, gives 0x022EBA.
instruction bus error. The processor detects the instruction bus error on prefetching an instruction, but it sets the IBUSERR flag to 1 only if it attempts to issue the faulting instruction. When the processor sets this bit it does not write a fault address to SCB->BFAR. Potential reasons: a) Branch to invalid memory regions for example caused by incorrect function pointers. b) Invalid return due to corrupted stack pointer or stack content. c) Incorrect entry in the exception vector table.
How can I debug this further. Also, what does the 0xCAFEBABE in R3 of the registers window mean? I doubt this is just some random address
Edit 01 Aug for Clarification The issue manifests itself in the following way:
  1. Connect Smart phones and external device to my device.
  2. Let the devices run. The external devices generate data at a rate of 25Hz. In my event handler for the notification , I notify the smartphones with the new data and add an app scheduler event to the queue to log the received data.
  3. Eventually (after a few minutes), I get a Bus Fault or usage fault. This happens sometime between finishing processing an app scheduler event and processing the next one in the queue. It does not happen in my BLE service event handlers. I have not seen any issues when there is not another app scheduler event to process.
If I don't enable the Bus Fault and Usage fault handlers then The code goes into the hard fault handler.
If I look at the call stack when in the hardfault handler, there is no information. The image below shows the register values from the hardfault handler with the bus fault and usage fault handlers turned off (in this case it looks like I got a bus fault).
image description
  • I afraid you just over complicated the debugging process. Could you describe what exactly happen when "it starts receiving usage faults." Please try to follow this guide.
  • Hi Hung Bui, I have already got the app_error_handler defined and have been using it however, when I see this problem, it does not go into the error handler. It would go into the hard fault handler until I enabled the usage and bus fault handlers like this
    SCB->SHCSR |= SCB_SHCSR_USGFAULTENA_Msk | SCB_SHCSR_BUSFAULTENA_Msk | SCB_SHCSR_MEMFAULTENA_Msk;
  • If you don't enable the SCB what would happens ? Where in the code the hardfault handler's stack pointed to ? Please try to describe what you observed before you go in to debugging. What exactly happened when "it starts receiving usage faults." ?
  • So lots of good information there. Going back to the original usage fault. You have a little more information, you know that the p_event_data was 0x20009b42 and the size of the event was 31 bytes (0x0000001f), that from the stacked R0 and R1 assuming they didn't change before the fault occurred. If they make sense, it sounds like you didn't get far after bx r7
    You also have the PC at the point of the fault which according to that trace is 0x00000000. That doesn't look good. (don't understand the PC in the second image). So my first guess here would be you've jumped to 0x00000000, whatever is there (the initial stack pointer) disassembles as something which causes a usage fault, probably an invalid instruction.
    I can't see where r7 comes from, that I assume is the address of the event_handler which was loaded a little earlier from the event handling structure. If any of that code used but didn't destroy r2, r3 or any of the other stacked registers, you might be able to see what r7 was loaded with. If that was zero, the bx r7 would have caused what you're seeing.
    If that's the case then something reset the event_handler to 0x00000000 (or you stomped over your memory). I don't know what resets that to zero but possibly a de-registration of the event handler might. Are you deregistering the event handler anywhere whilst you still have events to process?
  • Thanks RK.
    r7 is the event_handler. I think I'm seeing the same problem manifest itself as usage and bus faults. I've narrowed this down and it seems that somehow the m_queue_event_headers buffer is being corrupted. I see that the vaules for event_size and/or event_handler are being read differently to what I set them as. here is an example trace:
