Hi there,
I am trying to measure environment below 0 C but the app reboots and refuse to connect with thingy52 at lower temperatures. Do I have to set up anything else?
Hi there,
BTW
I had a quick look at the Android code,App source code but its not my area of experience and as far as I could see the Temperature seemed to arrive in "EXTRA_DATA" but I couldnt see any code where it was performing a calculation
There is this code
github.com/.../ThingyListenerHelper.java
I suspect the problem is that they may be using an unsigned 8 bit value for this, in which case -5 may show up as 250
Hi Rony
Well spotted, this appears to be a bug in the firmware.
The temperature sensor should be able to measure temperatures at least down to -40C, but negative numbers are not handled properly in the code.
We are working on a new release of the Thingy firmware, and will aim to fix this in the same release.
An exact release date is not set, but it should be out relatively soon ;)
Best regards
Torbjørn
That is it, yes :)
Thanks Torbjøn
