How to jump from Bootloader to Application (nrf51822)
Currently, I am trying to develop nrf51822 (MDBT40) using Nordic SDK v12 (S130). The programmer I used is DAPLink from RedBear.
I am wondering how to make program to jump from bootloader to application code.
This is what I have don:
  • Flash bootloader_secure example as my bootloader program:
    • Go to bootloader_secure/pca10028/armgcc/ and type "make clean; make";
    • Copy the generated .hex file in _build directory;
    • Merge the provided s130_nrf51_2.0.1_softdevice.hex with .hex file using:
      ./mergehex -m s130_nrf51_2.0.1_softdevice.hex nrf51422_xxac.hex -o bootloaderout.hex
    • Drag bootloaderout.hex file into virtual file system created by DAPLink for flashing bootloader;
  • Flash Beacon Example as Application Firmware:
    • Similar to previous steps, get .hex file by making the program;
      ./mergehex -m s130_nrf51_2.0.1_softdevice.hex nrf51422_xxac.hex -o appout.hex
    • Drag appout.hex file into virtual file system created by DAPLink for flashing application code;
From what I observed, my nrf51822 only execute the beacon app, with the secure DFU bootloader being ignore. However, from what I think, the nrf51822 should execute bootloader code, after which the application code will be executed. This can be explained by following statement in main.c from bootloader:
nrf_bootloader_app_start(MAIN_APPLICATION_START_ADDR); // the MAIN_APPLICATION_START_ADDR looks like the increment of SoftDevice
Can anyone suggest me where the mistake I may make. Thanks!
  • Thanks Bjørn, as you said, I have did following trials:
    • merge outputapp.hex and outputbootloader.hex, for getting a single out.hex. The process of merge completed successfully! However when I flashed to device, only bootloader code can be executed with application code being ignored!
    • The based on previous code, I flash outapp.hex (application code + softDevice) again, only application code works with bootloader being ignored..
    I am guessing the reason is that I didn't configure the linker file. As your reference, here is the linker file of application code, and the device I used is 16KB RAM 256KB Flash nrf51822 chip. Could you please help me check whether this is correct? Thanks!
    MEMORY
        FLASH (rx) : ORIGIN = 0x1b000, LENGTH = 0x25000
        RAM (rwx) :  ORIGIN = 0x200033b0, LENGTH = 0x4c50
  • After trying out many parameters, I think the reason is that the application code is flashed to wrong paces. Here is my modified linker file for application code, which I think it is correct for 16KB RAM:
    MEMORY
        RAM (rwx) :  ORIGIN = 0x20002080, LENGTH = 0x1800
    However, it looks like it still doesn't work (the bootloader can be executed successfully, however the it cannot jump to application code). Could you please indicate where the problem might be? Thanks!
  • The length of the application flash section is incorrect, it should be 0x21000 if the bootloader starts at 0x3C000. Could you post the linker script for the bootloader you're using?
  • Thanks Bjørn, as your reference, after double checking the hardware specification an datasheet, the nrf51822 chip I used has 32kB RAM 256KB Flash (RedBear Nano V1.5).
    I used the default bootloader linker scripts in Nordic V12 SDK:
    MEMORY
        FLASH (rx) : ORIGIN = 0x3AC00, LENGTH = 0x5000
        RAM (rwx) :  ORIGIN = 0x20002C00, LENGTH = 0x5380
        NOINIT (rwx) :  ORIGIN = 0x20007F80, LENGTH = 0x80
        BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
        UICR_BOOTLOADER (r) : ORIGIN = 0x10001014, LENGTH = 0x04
    And here are the linker scripts I used for application code:
    MEMORY
    Could you please help me confirming whether the parameters are correct? And thank you for helping me out these days!
  • You need to adjust the size of the application flash section as 0x1B000 + 0x25000 = 0x40000 (256kB), i.e. there is no room for the bootloader. Adjusting the size to 0x210000, i.e. 0x1B000 + 0x1FC00 = 0x3A000. Also, since you're using the 32kB variant of the nRF51822 you can increase the RAM size to 0x5F00.
