ble_app_uart_c example not work
Hello!
I have:
  • nRF52840-Preview-DK (pca10056)
  • nRF5_SDK_13.0.0_04a0bfd (s140)
I load **nRF5_SDK_13.0.0_04a0bfd\examples\ble_central\ble_app_uart_c\hex\ble_app_uart_c_pca10056_s140.hex** to first board and **nRF5_SDK_13.0.0_04a0bfd\examples\ble_peripheral\ble_app_uart\hex\ble_app_uart_pca10056_s140.hex** to second board, and it work fine.
Next, I load SoftDevice via nRFgo studio to first board, compile ble_app_uart in IAR and load hex file. It work fine.
Next, I load SoftDevice via nRFgo studio to second board, compile **ble_app_uart_c** in IAR and load hex file. This does not work. I compile **ble_app_uart_c** in Keil and load hex file.  It is not work too: Board get error and reset when try ble_nus_c_tx_notif_enable(p_ble_nus_c) in ble_nus_c_evt_handler... Function  ble_nus_c_tx_notif_enable return NRF_ERROR_INVALID_STATE error, because p_ble_nus_c->handles.nus_tx_cccd_handle == BLE_GATT_HANDLE_INVALID...
Please help me!
    Have you done any changes/modifications to the code? Did you use the s140_nrf52840_5.0.0-2.alpha_softdevice ?
  • Thank! Yes? it is! I did not any changes/modifications to the code... And I use s140_nrf52840_5.0.0-2.alpha_softdevice... Regards!
  • I’m not seeing this problem when I test this here. You could test with SDK 14, and see if that solves the problem.
    You should also use the latest nRF5 command line tools and Segger J-Link drivers.
    General note on debugging with the SoftDevice: Note that the BLE link will get disconnected when hitting a breakpoint, because the radio will be halted, and the radio will therefore not be able to transmit the necessary packets to keep the connection. The link will disconnected after a timeout given in the connect request (or a connection parameter update).
  • Hello, thank for answert!
    I check SDK14. Hex example work fine. Commpiling in Keil and downloading with SoftDevice work fine too. But commpiling in IAR and downloading with SoftDevice do not work ((( I think it is my mistake, because I use IAR version 6.70.1
    And please, tell me, can I do this on SDK14: I need device whith Long Range (how I know, I must use s140_nrf52840_5.0.0-3.alpha_softdevice), device will be connect to 1 master and 8 slave device, and each device must have client and server NUS (I wanted use l2cap, but support of l2cap was removed)... Is it posible to do? And what example must I use for it? I look to: ble_central\ble_app_uart_c, ble_peripheral\ble_app_uart, ble_central_and_peripheral\experimental\ble_app_att_mtu_throughput (from s140_nrf52840_5.0.0-3.alpha)?
    Regards!
  • Yes, that is most likely the issue. We are using IAR Workbench version 7.80.4 for testing and verification.
    That is not a problem. The Softdevice have support for 20 concurrent connections, where you can freely configure each link in any combination between Peripheral and Central.
    I think support for Connection Oriented Channels will be added in S140 when it goes out of alpha. See this post.
    Yes, but unfortunately the ble_app_uart and ble_app_uart_c example does not support this ‘out-of-the-box’ . You will have to combine both the ble_app_uart and ble_app_uart_c examples in order to run both NUS client and server on the same device. The ble_app_att_mtu_throughput or the ble_app_hrs_rscs_relay example should give some idea how to run both server and client on the same device. Get the code working first with support for 1 master and 1 slave. Since you need 8 slave connections, you will also have to implement support for the NUS client to handle this ammunt of devices(only support 1 connection by default). I recommend to take a look at the ble_app_multilink_central example to see how it’s done there. This post could also be a starting point for that.
