Any Android example about BroadcastUpdater to receive BLE notifications from the Device?
Hi!
I'm trying to receive notification on a characteristic that I've written before but I can't. I've activated the Notification in that characteristic, after that I write the characteristic and when I debug, the onCharacteristicChanged method never executes and I watch that the characteristic value has the value that I wrote.
private final static String TAG = BLEService.class.getSimpleName();
    Context context;
    private BluetoothManager mBluetoothManager;
    private BluetoothAdapter mBluetoothAdapter;
    private String mBluetoothDeviceAddress;
    private BluetoothGatt mBluetoothGatt;
    private int mConnectionState = STATE_DISCONNECTED;
    BluetoothGattService mService;
    private static final int STATE_DISCONNECTED = 0;
    private static final int STATE_CONNECTING = 1;
    private static final int STATE_CONNECTED = 2;
    public final static String ACTION_GATT_CONNECTED ="com.example.bluetooth.le.ACTION_GATT_CONNECTED";
    public final static String ACTION_GATT_DISCONNECTED ="com.example.bluetooth.le.ACTION_GATT_DISCONNECTED";
    public final static String ACTION_GATT_SERVICES_DISCOVERED ="com.example.bluetooth.le.ACTION_GATT_SERVICES_DISCOVERED";
    public final static String ACTION_DATA_AVAILABLE ="com.example.bluetooth.le.ACTION_DATA_AVAILABLE";
    public final static String EXTRA_DATA ="com.example.bluetooth.le.EXTRA_DATA";
    public final static String SERVICE = BLEUUID.SERVICE;
    public final static UUID PIN_CHARACTERISTIC = UUID.fromString(BLEUUID.PIN_CHARACTERISTIC_UUID);
    private final BluetoothGattCallback mGattCallback = new BluetoothGattCallback() {
        @Override
        public void onConnectionStateChange(BluetoothGatt gatt, int status, int newState) {
            String intentAction;
            if (newState == BluetoothProfile.STATE_CONNECTED) {
                intentAction = ACTION_GATT_CONNECTED;
                mConnectionState = STATE_CONNECTED;
                broadcastUpdate(intentAction);
                Log.i(TAG, "Connected to GATT server.");
                // Attempts to discover services after successful connection.
                Log.i(TAG, "Attempting to start service discovery:" +
                        mBluetoothGatt.discoverServices());
            } else if (newState == BluetoothProfile.STATE_DISCONNECTED) {
                intentAction = ACTION_GATT_DISCONNECTED;
                Log.i(TAG, "Disconnected from GATT server.");
        @Override
        public void onServicesDiscovered(BluetoothGatt gatt, int status) {
            if (status == BluetoothGatt.GATT_SUCCESS) {
                for (BluetoothGattService service : gatt.getServices()) {
                    if ((service == null) || (service.getUuid() == null)) {
                        continue;
                    if (BLEUUID.SERVICE.equalsIgnoreCase(service.getUuid().toString())) {
                        mService = service;
                broadcastUpdate(ACTION_GATT_SERVICES_DISCOVERED);
            } else {
                Log.w(TAG, "onServicesDiscovered received: " + status);
        @Override
        public void onCharacteristicRead(BluetoothGatt gatt,BluetoothGattCharacteristic characteristic,int status) {
                broadcastUpdate(ACTION_DATA_AVAILABLE, characteristic);
                broadcastUpdate(EXTRA_DATA, characteristic);
                Log.i("CARAC","CARACTERISTICA LEIDA onCharacteristicRead()");
        @Override
        public void onCharacteristicChanged(BluetoothGatt gatt,BluetoothGattCharacteristic characteristic) {
            readCharacteristic(characteristic);
    private void broadcastUpdate(final String action) {
        final Intent intent = new Intent(action);
        sendBroadcast(intent);
    @TargetApi(Build.VERSION_CODES.JELLY_BEAN_MR2)
    private void broadcastUpdate(final String action,final BluetoothGattCharacteristic characteristic) {
        if (PIN_CHARACTERISTIC.equals(characteristic.getUuid())) {
            final String pin = characteristic.getStringValue(0);
            intent.putExtra(EXTRA_DATA, String.valueOf(pin));
        } else {
            // For all other profiles, writes the data formatted in HEX.
            final byte[] data = characteristic.getValue();
            if (data != null && data.length > 0) {
                final StringBuilder stringBuilder = new StringBuilder(data.length);
                for(byte byteChar : data)
                    stringBuilder.append(String.format("%02X ", byteChar));
                intent.putExtra(EXTRA_DATA, new String(data) + "\n" + stringBuilder.toString());
    public class LocalBinder extends Binder {
        BLEService getService() {
            return BLEService.this;
    @Override
    public IBinder onBind(Intent intent) {
        return mBinder;
    @Override
    public boolean onUnbind(Intent intent) {
        close();
        return super.onUnbind(intent);
    private final IBinder mBinder = new LocalBinder();
     public boolean initialize() {
        if (mBluetoothManager == null) {
            mBluetoothManager = (BluetoothManager) getSystemService(Context.BLUETOOTH_SERVICE);
                return false;
        mBluetoothAdapter = mBluetoothManager.getAdapter();
        if (mBluetoothAdapter == null) {
            return false;
        return true;
    public boolean connect(final String address) {
        if (mBluetoothAdapter == null || address == null) {
            return false;
        if (mBluetoothDeviceAddress != null && address.equals(mBluetoothDeviceAddress)
                && mBluetoothGatt != null) {
            if (mBluetoothGatt.connect()) {
                mConnectionState = STATE_CONNECTING;
                return true;
            } else {
                return false;
        final BluetoothDevice device = mBluetoothAdapter.getRemoteDevice(address);
        if (device == null) {
            return false;
        mBluetoothGatt = device.connectGatt(this, false, mGattCallback);
        mBluetoothDeviceAddress = address;
        return true;
    public void disconnect() {
        if (mBluetoothAdapter == null || mBluetoothGatt == null) {
            return;
        mBluetoothGatt.disconnect();
    public void close() {
        if (mBluetoothGatt == null) {
            return;
        mBluetoothGatt.close();
        mBluetoothGatt = null;
        Log.e("CIERRE", "CONEXION CERRADA");
    public void readCharacteristic(BluetoothGattCharacteristic characteristic) {
            return;
        mBluetoothGatt.readCharacteristic(characteristic);
        Log.i("READ", "CARACTERISTICA LEIDA");
    public void setCharacteristicNotification(BluetoothGattCharacteristic characteristic, boolean enabled) {
            return;
        mBluetoothGatt.setCharacteristicNotification(characteristic, enabled);
        if (PIN_CHARACTERISTIC.equals(characteristic.getUuid())){
            BluetoothGattDescriptor descriptor =   new BluetoothGattDescriptor(UUID.nameUUIDFromBytes(BLEUUID.CONFIG_UUID.getBytes()),
                            BluetoothGattDescriptor.PERMISSION_WRITE_SIGNED);
            descriptor.setValue(BluetoothGattDescriptor.ENABLE_NOTIFICATION_VALUE);
            mBluetoothGatt.writeDescriptor(descriptor);
    public List<BluetoothGattService> getSupportedGattServices() {
        if (mBluetoothGatt == null) return null;
        return mBluetoothGatt.getServices();
    public void sendCharacteristic(String pin, BluetoothDevice device){
        byte[] pinByte = pin.getBytes();
        int pinInt = Integer.valueOf(pin);
        BluetoothGattCharacteristic ch = (BluetoothGattCharacteristic) mService.getCharacteristic(UUID
                .fromString(BLEUUID.PIN_CHARACTERISTIC_UUID));
        ch.setWriteType(BluetoothGattCharacteristic.WRITE_TYPE_DEFAULT);
        ch.setValue(pin);
        Toast.makeText(context, "CARACTERISTICA ASIGNADA", Toast.LENGTH_SHORT).show();
        connect(device.getAddress());
        setCharacteristicNotification(ch, true);
        if (mBluetoothGatt.writeCharacteristic(ch)) {
            Toast.makeText(context, "CARACTERISTICA ESCRITA", Toast.LENGTH_SHORT).show();
        mBluetoothGatt.readCharacteristic(ch);
        byte[] value = ch.getValue();
        String result = new String(value);
        Toast.makeText(context,result,  Toast.LENGTH_LONG);
Somebody knows what`s the problem?
