SDK12.3 flash storage
I want to store some data into flash. Whether there are relevant application notes or program code? Thanks
  • Do you use softdevice or not ? If you use softdevice please have a look at this fds usage here.
    If you don't use softdevice, please have a look at the SDK example \examples\peripheral\flashwrite
  • use softdevice, this test code:link text
    static uint8_t fs_callback_flag;
    static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
    	if (result != FS_SUCCESS)
    		bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
    		NRF_LOG_INFO("fstorage command successfully completed\n\r");
    		fs_callback_flag = 0;
    static void power_manage(void)
    	uint32_t err_code = sd_app_evt_wait();
    void fstorage_test(void)
    	static char char_data[5];
    	static char special_char_data[5];
    	static uint32_t data;
    	uint32_t flash_data[4];
    	FS_REGISTER_CFG(fs_config_t fs_config) =
    		.callback  = fs_evt_handler,
    		.num_pages = NUM_PAGES_SN,
    		.priority  = 0xFD
    	fs_ret_t ret = fs_init();
    	if (ret != FS_SUCCESS)
    	// Erase one page (page 0).
    	NRF_LOG_INFO("Erasing a flash page at address 0x%X\r\n", (uint32_t)fs_config.p_start_addr);
    	fs_callback_flag = 1;
    	ret = fs_erase(&fs_config, fs_config.p_start_addr, 1, NULL);
    	while(fs_callback_flag == 1)  {power_manage();}
    	//Read the first 4 words of the page
    	NRF_LOG_INFO("Reading from flash address 0x%X: ", (uint32_t)fs_config.p_start_addr);
    	for(int i=0; i<4; i++)
    		flash_data[i] = *(fs_config.p_start_addr + i);
    		NRF_LOG_INFO("%X ", flash_data[i]);
    	//Write first word
    	data = 0x4455AABB;
    	NRF_LOG_INFO("Writing data 0x%X to address 0x%X\r\n", data, (uint32_t)fs_config.p_start_addr);
    	ret = fs_store(&fs_config, fs_config.p_start_addr, &data, 1, NULL);      //Write data to memory address 0x0003F00. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
    	//Write second word
    	data = 0;
    	strcpy(char_data, "buzz");
    	char_data[4] = '\0';
    	data |= (char_data[0] << 24);
    	data |= (char_data[1] << 16);
    	data |= (char_data[2] <<  8);
    	data |= (char_data[3] <<  0);
    	NRF_LOG_INFO("Writing string '%s' (0x%X) to address 0x%X\r\n", (uint32_t)char_data, data, (uint32_t)fs_config.p_start_addr + 4);
    	ret = fs_store(&fs_config, fs_config.p_start_addr + 1, &data, 1, NULL);      //Write data to memory address 0x0003F000. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
    	//Write third word
    	data = 0;
    	strcpy(special_char_data,"~!@#");
    	special_char_data[4] = '\0';
    	data |= (special_char_data[0] << 24);
    	data |= (special_char_data[1] << 16);
    	data |= (special_char_data[2] <<  8);
    	data |= (special_char_data[3] <<  0);
    	NRF_LOG_INFO("Writing string '%s' (0x%X) to address 0x%X\r\n", (uint32_t)special_char_data, data, (uint32_t)fs_config.p_start_addr + 8);
    	ret = fs_store(&fs_config, fs_config.p_start_addr + 2, &data, 1, NULL);      //Write data to memory address 0x0003F000. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
    	//Read the first 4 words of the page and print in hex format
    	NRF_LOG_INFO("Reading from flash address 0x%X (hex): ", (uint32_t)fs_config.p_start_addr);
    	//Read the first 4 words of the page and print in ascii format
    	NRF_LOG_INFO("Reading from flash address 0x%X (ascii): ", (uint32_t)fs_config.p_start_addr);
    		char characters[4];
    		characters[0] = flash_data[i] >> 24;
    		characters[1] = flash_data[i] >> 16;
    		characters[2] = flash_data[i] >>  8;
    		characters[3] = flash_data[i] >>  0;
    		NRF_LOG_INFO("%c%c%c%c ", characters[0], characters[1], characters[2], characters[3]);
    Called directly in the main.c, no problem。 If, called in a callback function, the application stops running
  • Can you check what is the error ? is it hardfault ?
    You need to make sure the priority of the interrupt where you call the function is APP_LOW so that you can call flash API. Otherwise you have to use app scheduler to call the flash's functions in main context.
