Unable to connect noridic nrf51 with andriod 5.x
Hello everyone,
I tried to connect with nrf51 with andriod 5.x .On connection indication the Master (android ) shows the following values of connection parameter (taken from sniffer):
  connInterval: 37,50  ms
  connSlaveLatency: 0
  connSupervisionTimeout: 20000,00  ms
The nrf52 sends with L2CAP request following values on connection parameter update request:
  connIntervalMin: 21,25  ms
  connIntervalMax: 45,00  ms
  connSlaveLatency: 0
  connSupervisionTimeout : 200  ms
It gets connection parameter update response as
Connection Parameters accepted
Then i see on link layer (after about 700 ms counting from the CONNECT_IND) LL_CONNECTION_UPDATE_IND with following values of parameter:
connInterval: 7,50  ms
connSlaveLatency: 0
connSupervisionTimeout: 20000  ms
Right after that the master sends another LL_CONNECTION_UPDATE_IND with another set of values:
connInterval: 30,00  ms
connSlaveLatency: 0
connSupervisionTimeout: 200  ms
Then the connection breaks immediately after LL_CONNECTION_UPDATE_IND.
Also I have defined following values for connection parameter in the firmware:
   MIN_CONN_INTERVAL                    62.5 ms
   MAX_CONN_INTERVAL                   250 ms
     SLAVE_LATENCY                            0
    CONN_SUP_TIMEOUT                   40000
     FIRST_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)
    NEXT_CONN_PARAMS_UPDATE_DELAY        APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)
    MAX_CONN_PARAMS_UPDATE_COUNT         3
Why the connection is gets broken again and again? Why is the NRF51 always sending the L2CAP Connection Parameter Update Requests?
waiting for your kind reply.
Regards
MAbbas
