Call function from gdb at breakpoint?
Is it possible to call an arbitrary function at a breakpoint in gdb on the nRF52? I know you can with normal gdb, but I haven't been able to make it work with the cross ARM version. Thanks.
SDK13 PCA10040/nRF52832 GNU gdb (GNU Tools for ARM Embedded Processors 6-2017-q1-update) Eclipse OSX
    I just tested this with gcc-arm-none-eabi-6_2-2016q4 on the blinky example. I added this function which blinks with 1 sec delay instead of 500 ms:
    void test_function(void)
        for (int i = 0; i < LEDS_NUMBER; i++)
            bsp_board_led_invert(i);
            nrf_delay_ms(1000);
    Remember to run this function once before entering while(1) loop to ensure that gcc does not dump it.
    arm-none-eabi-gdb _build/*.out
    (gdb) target remote :2331
    (gdb) load
    (gdb) mon reset
    (gdb) c
    <break somewhere in your code once the 500 ms routine starts, using CTRL+C>
    (gdb) call test_function()
    It is very important that you add the parentheses when calling "call func()". Once it is finished calling the function, it will go back to a halted state.
    Happy debugging! Cheers, Håkon
