FDS write fail
Hi all,
I have some problem with the FDS write function.
This is some example codes for my FDS write:
// Global variables
static uint16_t fileID;
static uint16_t recordKey;
static fds_record_t        record;
static fds_record_desc_t   record_desc;
static fds_record_chunk_t  record_chunk;
static fds_flash_record_t  flash_record;
static fds_find_token_t    ftok;
struct
   uint16_t     	variable1[7];
   uint16_t     	variable2;
   uint16_t		variable3;
   uint8_t     	        variable4[7];
   uint8_t		variable5;
} saveData;
struct
  uint16_t            variable6;
  uint8_t              variable 7[7];
} saveData2;
// Inside Main( )
fileID = 0x1000;
recordKey = 0x2000;
record_chunk.p_data         = &saveData;
record_chunk.length_words   = sizeof(saveData)/sizeof(uint32_t);
record.file_id              = fileID;
record.key                  = recordKey;
record.data.p_chunks       = &record_chunk;
record.data.num_chunks   = 1;
ret = fds_write();
if (ret != FDS_SUCCESS)
NRF_LOG_INFO("Write History fail!\r\n");
fileID = 0x1000;
recordKey = 0x2001;
record_chunk.p_data         = &saveData2;
record_chunk.length_words   = sizeof(saveData2)/sizeof(uint32_t);
ret = fds_write();
My fds_write function looks like this:
static ret_code_t fds_write(void)
	ret_code_t ret = fds_record_write(&record_desc, &record);
			return ret;
	while (write_flag==0);
	NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
	return NRF_SUCCESS;
The first write is successful but the second write is unsuccessful. Why does this happen?
