PWM and TWI not working at the same time
Hello, i have Nrf52840, here is the code for PWM
APP_PWM_INSTANCE(PWM1, 1);
uint8_t cBuzzer::_PWM_init(uint32_t Time_uS){
app_pwm_uninit(&PWM1);
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(Time_uS, Buzzer_Pin);
/* Initialize and enable PWM. */
if (app_pwm_init(&PWM1, &pwm1_cfg, NULL) != Successfully) {return Error ;}
app_pwm_enable(&PWM1);
return Successfully; }
void cBuzzer::Set_DutyCycle(uint8_t xDuty_Cycle)
		while (app_pwm_channel_duty_set(&PWM1, 0, xDuty_Cycle) == NRF_ERROR_BUSY);
		Current_Duty_Cycle = xDuty_Cycle;
PWM is working Perfectly.
here is the code for TWI
static const nrf_drv_twi_t I2C_master_Instance = NRF_DRV_TWI_INSTANCE(0);
uint8_t cI2C::inilization()
			ret_code_t ret;
			const nrf_drv_twi_config_t config =
				.scl = _SCL_PinNumber,
				.sda = _SDA_PinNumber,
				.frequency = NRF_TWI_FREQ_100K,
				.interrupt_priority = APP_IRQ_PRIORITY_HIGH
			do
				ret = nrf_drv_twi_init(&I2C_master_Instance, &config, NULL, NULL);
				if (NRF_SUCCESS != ret)
				nrf_drv_twi_enable(&I2C_master_Instance);
			} while (0);
			_Error = ret;
			return ret;
uint8_t cI2C::Write(uint8_t Slave_addr, uint8_t * Data_TO_Write, uint32_t Number_of_bytes_TO_Writes)
			ret_code_t ret_code;
			ret_code = nrf_drv_twi_tx(&I2C_master_Instance, Slave_addr, Data_TO_Write, Number_of_bytes_TO_Writes, false);
			_Error = ret_code;
			return ret_code;
uint8_t cI2C::Read(uint8_t Slave_addr, uint8_t Address_to_Read ,uint8_t * Data_TO_Read)
			ret_code =  Write(Slave_addr, &Address_to_Read,1);
			if (ret_code != NRF_SUCCESS)
				_Error = ret_code;
				return ret_code;
			ret_code = nrf_drv_twi_rx(&I2C_master_Instance, Slave_addr, Data_TO_Read, 1);
			_Error = ret_code;
			return ret_code;
TWI is also working.
when i combine the both then PWM is working but TWI is not. i connect the BME280 temperature sensor with TWI. i thought may be both of library share the same timer ? any solution will be appreciated.
