I am developing an application which uses 2 nrf52 running sdk 12.3 and softdevice 132 V3.
The central device appears to be saving and whitelisting the two peers, but it won't connect to them when I actually enable the whitelist - disable the whitelist and it works fine.
static void scan_start(bool refreshWhitelist)
uint32_t flash_busy;
(void) fs_queued_op_count_get(&flash_busy);
if (flash_busy != 0)
m_memory_access_in_progress = true;
return;
ble_gap_addr_t whitelist_addrs[maxWhitelist];
ble_gap_irk_t whitelist_irks[maxWhitelist];
memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
memset(whitelist_addrs, 0x00, sizeof(whitelist_irks));
uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
#if (NRF_SD_BLE_API_VERSION == 2)
ble_gap_addr_t * p_whitelist_addrs[maxWhitelist];
ble_gap_irk_t * p_whitelist_irks[maxWhitelist];
for (uint32_t i = 0; i < maxWhitelist; i++)
p_whitelist_addrs[i] = &whitelist_addrs[maxWhitelist];
p_whitelist_irks[i] = &whitelist_irks[maxWhitelist];
ble_gap_whitelist_t whitelist =
.pp_addrs = p_whitelist_addrs,
.pp_irks = p_whitelist_irks,
if(refreshWhitelist) whitelist_load();
ret_code_t ret;
ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
m_scan_params.active = 1;
m_scan_params.interval = SCAN_INTERVAL;
m_scan_params.window = SCAN_WINDOW;
if (((addr_cnt == 0) && (irk_cnt == 0)) ||
(m_whitelist_disabled))
// Don't use whitelist.
m_scan_params.selective = 0;
m_scan_params.p_whitelist = NULL;
#if (NRF_SD_BLE_API_VERSION == 3)
m_scan_params.use_whitelist = 0;
m_scan_params.adv_dir_report = 0;
m_scan_params.timeout = 0x0000; // No timeout.
// Use whitelist.
whitelist.addr_count = addr_cnt;
whitelist.irk_count = irk_cnt;
m_scan_params.selective = 1;
m_scan_params.p_whitelist = &whitelist;
m_scan_params.use_whitelist = 1;
m_scan_params.adv_dir_report = 1;
ret = sd_ble_gap_scan_start(&m_scan_params);
APP_ERROR_CHECK(ret);
The whitelist_load() and peer_list_get() functions are the same as the examples they are taken from. In debugger (I am developing this using a Rigado dev board & Eclipse) I see that sd_ble_gap_scan_start() returns NRF_SUCCESS whether or not I start it with the whitelist enabled or disabled.
My peripheral device is running peer manager, but never sets a whitelist. These are my security parameters for both devices.
sec_param.bond = true;
sec_param.mitm = false;
sec_param.lesc = 0;
sec_param.keypress = 0;
sec_param.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
sec_param.oob = false;
sec_param.min_key_size = 7;
sec_param.max_key_size = 16;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
I'm kind of stuck here.
