Central adds peripheral to the whitelist, but won't reconnect
I am developing an application which uses 2 nrf52 running sdk 12.3 and softdevice 132 V3.
The central device appears to be saving and whitelisting the two peers, but it won't connect to them when I actually enable the whitelist - disable the whitelist and it works fine.
static void scan_start(bool refreshWhitelist)
uint32_t flash_busy;
(void) fs_queued_op_count_get(&flash_busy);
if (flash_busy != 0)
	m_memory_access_in_progress = true;
	return;
ble_gap_addr_t whitelist_addrs[maxWhitelist];
ble_gap_irk_t  whitelist_irks[maxWhitelist];
memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
memset(whitelist_addrs, 0x00, sizeof(whitelist_irks));
uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
#if (NRF_SD_BLE_API_VERSION == 2)
ble_gap_addr_t * p_whitelist_addrs[maxWhitelist];
ble_gap_irk_t  * p_whitelist_irks[maxWhitelist];
for (uint32_t i = 0; i < maxWhitelist; i++)
    p_whitelist_addrs[i] = &whitelist_addrs[maxWhitelist];
    p_whitelist_irks[i]  = &whitelist_irks[maxWhitelist];
ble_gap_whitelist_t whitelist =
    .pp_addrs = p_whitelist_addrs,
    .pp_irks  = p_whitelist_irks,
if(refreshWhitelist) whitelist_load();
ret_code_t ret;
ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
						whitelist_irks, &irk_cnt);
m_scan_params.active   = 1;
m_scan_params.interval = SCAN_INTERVAL;
m_scan_params.window   = SCAN_WINDOW;
if (((addr_cnt == 0) && (irk_cnt == 0)) ||
    (m_whitelist_disabled))
    // Don't use whitelist.
        m_scan_params.selective   = 0;
        m_scan_params.p_whitelist = NULL;
    #if (NRF_SD_BLE_API_VERSION == 3)
        m_scan_params.use_whitelist  = 0;
        m_scan_params.adv_dir_report = 0;
    m_scan_params.timeout  = 0x0000; // No timeout.
    // Use whitelist.
        whitelist.addr_count     = addr_cnt;
        whitelist.irk_count      = irk_cnt;
        m_scan_params.selective   = 1;
        m_scan_params.p_whitelist = &whitelist;
        m_scan_params.use_whitelist  = 1;
        m_scan_params.adv_dir_report = 1;
ret = sd_ble_gap_scan_start(&m_scan_params);
APP_ERROR_CHECK(ret);
The whitelist_load() and peer_list_get() functions are the same as the examples they are taken from. In debugger (I am developing this using a Rigado dev board & Eclipse) I see that sd_ble_gap_scan_start() returns NRF_SUCCESS whether or not I start it with the whitelist enabled or disabled.
My peripheral device is running peer manager, but never sets a whitelist. These are my security parameters for both devices.
	sec_param.bond = true;
sec_param.mitm = false;
sec_param.lesc = 0;
sec_param.keypress = 0;
sec_param.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
sec_param.oob = false;
sec_param.min_key_size = 7;
sec_param.max_key_size = 16;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
I'm kind of stuck here.
  • @Nick: Please check , if both addr_cnt == 0 && irk_cnt == 0 , whitelist will not be used at least that what in the code you posted. Could you please double check ?
    You can check the IRK on the central side. Try to connect with 2 peripheral, one by one. And see if the IRK matched for each device when you repeat the test.
    Note that you need to make sure the address is resolvable random address, otherwise the IRK is not relevant (if they are static addresses then the address should be used for whitelisting).
