nRF52832 Disable Access Port protection
I'm able to successfully enable Access Port protection, either using nrfjprog or by setting NRF_UICR->APPROTECT register to 0xFFFFFF00 in code.
But I have a problem if I want to perform inverse operation - disable Access Port protection. I do it same way as in case of enable, but the value of APPROTECT is now 0xFFFFFFFF. Here is a code:
NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
	// Do nothing.
NRF_UICR->APPROTECT = 0xFFFFFFFF;
	// Do nothing.
// Turn off flash write enable and wait until the NVMC is ready:
NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
	// Do nothing.
When I run this code, CPU is still protected. I also tried to perform this by setting specific memory place to desired value and result is the same - protection is still enabled.
What am I doing wrong?
