RX_DR interrupt doesn't fire when ACK payload is in FIFO
I have some problem with NRF24L01+. I'm trying to make bidirectional connection between two devices with this chip. When I'm sending payload with ACK, TX_DS interrupt on PRX fire but RX_DR on PTX doesn't. I know that i have got this data because FIFO RX isn't empty. What condition should be fulfilled to RX_DR interrupt fire on ongoing data with ACK? Should I manually change state to PRIM_RX for checking moment?
    How does your interrupt routine look like? if you do a switch-case on the returned STATUS register you'll be fooled, as both RX_DR and TX_DS will be set. Be sure to mask each bit:
    if (RX_DR)
    if (TX_DS)
    if (MAX_RT)
    Also, make sure that the interrupt is enabled in the CONFIG register.
    Best regards Håkon
  • Håkon Alseth:
    Thanks a lot for your reply, but unfortunately it doesn't help me. :( My routine on PTX side looks like:
    1. Go to PTX mode.
    2. Send payload.
    3. While TX_DS ord MAX_RT doesn't fire, do nothing.
    4. If MAX_RT fire, set (clear ;)) this interrupt and send it again. Else if TX_DS fire, wait ~100ms then check RX_DR - in this moment, I know i get acknowledge packet because FIFO isn't empty and i'm printing it to console without problem. But RX_DR doesn't fire.
    As I know, I don't have to enable this interrupt in CONFIG register because it just set reflect on physical PIN, and I don't need this. Of course I enabled it but it doesn't help.
    Also I was trying to set PRX mode after sending the packet, but it doesn't help too.
  • It sounds like you are receiving the ACK and the payload at the same time. This will cause the STATUS register to be 0x6? (bit 5 and 6 set). If you do not clear this properly by reading the register, masking with 0x70, then writing back, the bit will always be set. If you then read out a payload from the FIFO (which is not there), you will execute an illegal operation seen from the radio statemachine.
    Can you post your code?
  • Ok, i found my mistake. Very dumb mistake. After TX_DS interrupt fire, I was cleaning it. Clearing by getting old STATUS value (0x30 well RX_DR was ok), mask it with (1 << TX_DS) and write to STATUS. When I get old value, I was cleaning also RX_DR. :( So everything is ok.
    But I have one more question. Now I get RX_DR interrupt, then getting RX FIFO and my RX_DR is clearing automatically with buffor. Is it normal, or I'm making another mistake? ;)
