SDK 14 migration: can't advertise. fstorage busy.
Hi there.
I recently migrated from SDK 13 to SDK 14.0.0 and followed the migration guide in detail. I've found that when I try to advertise, ble_advertising_start() will find that fstorage is in use and bail out, expecting to try again once it's no longer busy.
I can think of no valid reason that fstorage would be busy at the point I start advertising. How can I find out who's using it?
I also note that the HRS peripheral example app doesn't SOC events at the point where it calls NRF_SDH_BLE_OBSERVER(), but used to in SDK 13 and below. That handler would forward events to the fstorge module and the BLE advertising module. In SDK 14, the BLE advertising module registers itself as an observers of SOC events, but the fstorage module does not. Do we need to observe SOC events here and pass them on to the fstorage module, or does it look after itself somehow?
Here's the top of ble_advertising_start():
uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
                               ble_adv_mode_t            advertising_mode)
    uint32_t             ret;
    ble_gap_adv_params_t adv_params;
    if (p_advertising->initialized == false)
    p_advertising->adv_mode_current = advertising_mode;
    // Delay starting advertising until the flash operations are complete.
    if (flash_access_in_progress())
        p_advertising->advertising_start_pending = true;
        return NRF_SUCCESS;
Here's how I init the BLE stack, etc.:
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Overwrite some of the default configurations for the BLE stack.
    ble_cfg_t ble_cfg;
    memset(&ble_cfg, 0, sizeof(ble_cfg));
	// Three vendor-specific UUIDs: our own, Nordic's DFU service and Nordic's UART service.
    ble_cfg.common_cfg.vs_uuid_cfg.vs_uuid_count = 3;
    err_code = sd_ble_cfg_set(BLE_COMMON_CFG_VS_UUID, &ble_cfg, ram_start);
    // Enable BLE stack.
And here's my BLE advertising init:
void ble_advertise_out_of_box(void)
    ble_advertising_init_t init;
	ble_uuid_t adv_uuids[] = {{BTS_UUID_SERVICE, m_bts.uuid_type}};
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    init.advdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids = adv_uuids;
    // Advertising modes config.
    // Fast, then slow (both undirected).
    init.config.ble_adv_whitelist_enabled = false;
    init.config.ble_adv_directed_enabled = false;
    init.config.ble_adv_directed_slow_enabled = false;
    init.config.ble_adv_directed_slow_interval = 0;
    init.config.ble_adv_directed_slow_timeout = 0; // seconds (despite what the SDK header says, this is NOT number of tries)
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_interval = 0x0028; // 25 ms
    init.config.ble_adv_fast_timeout = 10; // seconds
    init.config.ble_adv_slow_enabled = true;
    init.config.ble_adv_slow_interval = 0x00A0; // 100 ms
    init.config.ble_adv_slow_timeout = 50; // seconds
    // From the SDK 14.0.0 HRS example app:
	// Start advertising in fast mode, not directed. From here, two things can happen:
    // * On a timeout, we go back to sys off.
    // * On a connection and bond, we continue happily through main().
	err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
When I try to advertise, I get no error, but I never get the on_adv_evt() call with BLE_ADV_EVT_FAST either.
Edit:
Debugging nrf_fstorage_is_busy() reveals that there's only one fstorage instance and it's using the SD API as expected:
(gdb) print p_fs
$1 = (const nrf_fstorage_t *) 0x20002254 <m_fs>
(gdb) print p_api
$2 = (nrf_fstorage_api_t *) 0x3f81c <nrf_fstorage_sd>
(gdb) cont
Here's 0x20002254 from my map file:
.fs_data        0x0000000020002254       0x14 load address 0x0000000000040354
                0x0000000020002254                PROVIDE (__start_fs_data, .)
 *(.fs_data)
 .fs_data       0x0000000020002254       0x14 _build/app/fds.c.o
                0x0000000020002254                m_fs
                0x0000000020002268                PROVIDE (__stop_fs_data, .)
Edit:
The peer manager is indeed using fstorage at the time I'm trying to advertise. Here's the stack trace from a breakpoint in the write() function in nrf_fstorage_sd.c:
Breakpoint 2, write (p_fs=0x20002254 <m_fs>, dest=462848, p_src=0x3f5c8 <page_tag_data>, len=8, p_param=0x0)
    at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fstorage/nrf_fstorage_sd.c:442
442	    if (!queue_get_next_free(&p_op))
(gdb) bt full
#0  write (p_fs=0x20002254 <m_fs>, dest=462848, p_src=0x3f5c8 <page_tag_data>, len=8, p_param=0x0) at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fstorage/nrf_fstorage_sd.c:442
        p_op = 0x20002254 <m_fs>
#1  0x00038d92 in nrf_fstorage_write (p_fs=0x20002254 <m_fs>, dest=462848, p_src=0x3f5c8 <page_tag_data>, len=8, p_context=0x0)
    at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fstorage/nrf_fstorage.c:159
No locals.
#2  0x00037682 in page_tag_write_data (p_page_addr=0x71000) at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fds/fds.c:325
        page_tag_data = {3735929054, 4045275646}
#3  0x0003820e in init_execute (prev_ret=0, p_op=0x200033a8 <m_op_queue>) at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fds/fds.c:1077
        i = 0
        write_reqd = false
        ret = 15
#4  0x0003854c in queue_process (result=0) at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fds/fds.c:1332
        ret = 67305472
        p_op = 0x200033a8 <m_op_queue>
#5  0x000385ee in queue_start () at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fds/fds.c:1392
No locals.
#6  0x000388f8 in fds_init () at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/libraries/fds/fds.c:1639
        ret = 0
        evt_success = {id = FDS_EVT_INIT, result = 0, {init = {pages_not_mounted = 0}, write = {record_id = 0, file_id = 0, record_key = 0, is_record_updated = false}, del = {record_id = 0,
              file_id = 0, record_key = 0, records_deleted_count = 0}, gc = {pages_skipped = 0, space_reclaimed = 0}}}
        op = {op_code = FDS_OP_INIT, {init = {step = FDS_OP_INIT_TAG_DATA}, write = {header = {record_key = 11521, length_words = 0, file_id = 10192, crc16 = 8192, record_id = 4294967289},
              p_data = 0x0, page = 48521, step = FDS_OP_WRITE_RECORD_ID, record_to_delete = 10204}, del = {step = FDS_OP_DEL_FILE_FLAG_DIRTY, file_id = 0, record_key = 10192,
              record_to_delete = 4294967289}}}
        init_opts = TAG_DATA
#7  0x0002e9a0 in pds_init () at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/ble/peer_manager/peer_data_storage.c:359
        ret = 0
#8  0x000301e2 in pm_init () at /Users/eliot/dev/nRF5_SDK_14.0.0_3bcc1f7/components/ble/peer_manager/peer_manager.c:500
        err_code = 166071
#9  0x000288ea in peer_manager_init () at ../ble_periph.c:862
        sec_param = {bond = 0 '\000', mitm = 0 '\000', lesc = 0 '\000', keypress = 0 '\000', io_caps = 0 '\000', oob = 0 '\000', min_key_size = 128 '\200', max_key_size = 2 '\002', kdist_own = {
            enc = 0 '\000', id = 0 '\000', sign = 0 '\000', link = 0 '\000'}, kdist_peer = {enc = 1 '\001', id = 1 '\001', sign = 0 '\000', link = 0 '\000'}}
        err_code = 0
#10 0x000289f2 in ble_periph_init (p_device_id=0x20002248 <m_device_id> "000000DK", p_battery_voltage=0x200021b4 <m_battery_voltage>) at ../ble_periph.c:917
No locals.
#11 0x000293fe in main () at ../main.c:91
        err_code = 0
        main_loop_count = 0
        app_rev_major = 0
        app_rev_minor = 1
So my questions now are:
  1. Is it right that the write() is happening here?
  2. If so, why does ble_advertising.c's attempt to pick up where it left off not work? It should get a call to ble_advertising_on_sys_evt() later once the peer manager is done with fstorage:
    void ble_advertising_on_sys_evt(uint32_t evt_id, void * p_context) { ble_advertising_t * p_advertising = (ble_advertising_t *)p_context;
     switch (evt_id)
         //When a flash operation finishes, re-attempt to start advertising operations.
         case NRF_EVT_FLASH_OPERATION_SUCCESS:
         case NRF_EVT_FLASH_OPERATION_ERROR:
             if (p_advertising->advertising_start_pending)
                 p_advertising->advertising_start_pending = false;
                 ret_code_t ret = ble_advertising_start(p_advertising,
                                                        p_advertising->adv_mode_current);
                 if ((ret != NRF_SUCCESS) && (p_advertising->error_handler != NULL))
                     p_advertising->error_handler(ret);
         } break;
             // No implementation needed.
  • So this was, quite frustratingly, just down to a missing define in my app_config.h (like sdk_config.h, but partial, and applied over the top).
    It turns out it's entirely possible to build an app in which NRF_SDH_SOC_ENABLED is not defined or is 0 and therefore there are no SoC events going out to observers at runtime. You won't know it's not happening, even if you've got the BLE advertising module set up properly. I'd have expected the app not to link, but it does.
