Stop and restart APP_TIMER doesn't work with SDK12
I use an app_timer to periodically update sensor reading in my application. There is a characteristic used to change updating rate by stopping and restarting the app_timer:
app_timer_stop(m_our_char_timer_id);
app_timer_start(m_our_char_timer_id, APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER), NULL); //1000ms
It works fine with SDK11. But with SDK12, I couldn't receive any data package after stopping and restarting the app_timer. Weird thing is, usually after 5 to 6 minutes, it resumes updating again.
Any help is appreciated. Thanks.
  • I'll try that. Questions about the debugging setup, from app_error.c the app_error_handler doesn't look like the same as before. Where should I place a break point now?
    void app_error_handler(ret_code_t error_code, uint32_t line_num, const uint8_t * p_file_name)
          error_info_t error_info =
            .line_num    = line_num,
            .p_file_name = p_file_name,
             .err_code    = error_code,
           app_error_fault_handler(NRF_FAULT_ID_SDK_ERROR, 0, (uint32_t)(&error_info));
         UNUSED_VARIABLE(error_info);
    Another question is I'm using Eclipse and GCC instead of Keil, where should I define DEBUG?
