Can I configure GPIOTE to debug my signals?
I am using nrf52832 DK and I would like to use the GPIOs port to debug a couple of signals that I genereate within the MCU.
So far I have configured my GPIOTE module like this (I am using the LEDs for now as example to see that they change), but I am not sure how if I have to configure the GPIOTE more in order to make my signal available on that pin.
My definition
#define GPIO_OUTPUT_A  BSP_LED_0 //25  /**< Pin number for A signal debug. */
My GPIOTE config
static void gpiote_init(void){
    uint32_t            err_code;
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_SIMPLE(NRF_GPIOTE_INITIAL_VALUE_LOW);
    //Configuring A debug pin
    err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_A, &config);
    if (!nrf_drv_gpiote_is_init())
So if I would like to have the value of A,define as float for instance, how can I write it to the GPIO_OUTPUT_A ? Something like this
nrf_gpio_pin_write(GPIO_OUTPUT_A,(uint32_t)A);
Thanks in advance
  • Sure, i use that for signalling with LEDs or just for reading with Logical analyzer/oscilloscope as well. There are all functions available in \components\drivers_nrf\hal\nrf_gpio.h header file (first configure the PIN as output and then use set/clear functions to set it LOW or HIGH.) There are also HAL and blinky examples in nRF5 SDK, have you searched any?
