How to build a shared channel
I want to build a shared channel,but it seems that the shared channel is a little different from the broadcast channel. the shared channel 's slave node will have to send a broadcast date to config the address of the node,but I don't know how the code should be coded cause I can't find any routine that can be based on. Have any one coded the shared channel before?Can you tell me how to build a shared channel?
Thanks!
