Role of Central's Tx Power in connection with Peripheral
How does the Tx power impact the scanning and connection with a peripheral?
In detail, say if the peripheral can advertise at a Tx power of 4, 0 or -4 dB, then will it depend on the central's maximum(or device manufacturer's default value) of Tx power when it scans for the peripheral or not.
If the central can not exceed a power of 0dB, then does it make logical sense to have the peripheral advertise at a power of 4dB?
Also, we know how to manipulate the power for a peripheral, but are we allowed to change the same for a Central(an Android or iOS device)?
  • Note that most of low power radio chips (including all nRF5x) are having pretty much "fixed" sensitivity of receiver. So there is nothing like "Tx Power" or "RSSI threshold" on scanner's receiving HW stage. They simply either register and decode the packet through tuned antenna or not. On the other side transmitting stage have typically some wider or narrow possibility to tune the HW stage and emit more or less. So there you can do trade-offs how much power you want to invest into your "broadcasting" vs. what theoretical range of sight you need. But note that it's always combination of transmitter and receiver so you will have observer/central devices which will register some packets and other devices which will miss it when being side by side.
    Also note that when establishing connection you have two transmitter/receiver pairs and they can behave differently so in extreme cases (when your radio topology makes your signal close to low thresholds of receivers) you can see that packets from one side to another are OK while the other way are being "lost". So then you start to care about Tx Power on Central side (because that's used during transmitting part of connection interval from Master's point of view).
  • And better stop thinking about receivers in the same scale as Tx Power: they are having only "sensitivity" limit which is lower threshold where they stop being able to recognize signal from noise (typical -80 to -100dBm for BLE receivers). So as long as the receiver recognize the packet it will also measure some relative signal strength and that's combination of all the topology around (= how strongly transmitter shouts, what was around when waves traveled, how antenna and other stages before receiving circuit in SoC look etc.) Thinking about receivers as 0dBm or other fixed value doesn't help to understanding this picture, at least not me...
