Program skipping reset handler and system init in .s file right to a logging function
To my understanding, normally, either after a reset or powering up, the program should first run to Reset_Handler, then SystemInit, then __main.
Somehow, my program runs to none of the places above, and if you F11 all the way down (I'm using keil uv5), it will eventually hit this function:
uint32_t log_vprintf(uint32_t dbg_level, const char * p_filename, uint16_t line,
    uint32_t timestamp, const char * format, va_list arguments)
    uint32_t status = NRF_SUCCESS;
    if(m_log_callback != NULL)
        status = m_log_callback(dbg_level, p_filename, line, timestamp, format, arguments);
    return status;
(I'm trying to port the provisionee program of BLE Mesh to my board, and this is a module called "log.c" BTW. )
Or if you hit F5 on keyboard and let it run, it will go through none of those function (I set breakpoints there), and eventually stop at here, which is a random place by the look of it:
image description
And this is what it looks like at address 0x633abb86:
image description
Any idea how to approach this problem?
Edit: here's the project file, including the official program files and the softdevice which I'm using (S140 alpha 1):
Extract to a directory in F.7z
Extract it to a directory in F: with the name "BLE Mesh Official" and you should be good to go. Otherwise you may need to spend some time doing the inclusion path modification in the magic wand.
