Hi folks, I'm making progress with a program to get two nRF24L01p modules communicating with each other, but there are a couple of remaining problems. I hope someone can help with them, please:
- The PTX module seems to be transmitting my 3-byte payloads correctly, and the VDD_PA pin on that nRF24L01p pulses high (~2.0V) as expected. The PRX module even reports that it is receiving most packets from the PTX module (often 6 packets in a sequence, but then there's a 'timeout' reported). BUT the PRX module never seems to be sending back an ACK, and the PTX module consequently reports that no ACK has been received. The VDD_PA pin on the PRX chip never pulses high, either -- presumably because no ACK is being sent. Can anyone suggest what I'm doing wrong?
- I'm puzzled as to why the PRX module reports that 6 successive packets have been received successfully, but then reports a timeout with no packet received. Then it will report that the next 6 packets were received, before reporting another timeout + no packet received. And so on. This sounds a bit like some sort of timing problem, but I can't work out exactly what. Any suggestions? Thanks, JimR
