How to send 16 bit element array[10000] in BLE nus service in nrf52?
I am using 12 bit ADC in my application but data element more than 8bit is not send correctly, Also not receiving Array[10000] element. I am using nrf52.
Thank You, Ram
  • Sorry Ram, your question doesn't make sense. You will need to tell us much more: what exactly are you doing, what FW/example project/stack/SDk version/HW you use, what steps pass and where you see the problem. If you just say "I'm trying to send lot of 12-bit ADC samples over NUS and I don't see them on receiver's side" then obviously the only answer is "you have some bug in your FW or flaw in your design, go back and debug".
  • Several ways to do this, all of them covered numerous times in the forum. I'm a fan of doing something like this for 16 bits or two bytes (from here you can work out the for loops and counters required)
    nus_to_send_array[0] = (Array[0] & 0xFF00) >> 8;
    nus_to_send_array[1] = (Array[0] & 0x00FF);
    nus_to_send_array[18] = (Array[9] & 0xFF00) >> 8;
    nus_to_send_array[19] = (Array[9] & 0x00FF);
    ble_attempt_to_send(nus_to_send_array, sizeof(nus_to_send_array));
  • So then mark the right answer!
