My name is Bruno, and I am working with a Bluetooth module from u-blox(NINA B112-00B) which contains a nordicSemi board nRF52832 with a Cortex M4 processor. I'm getting this "Target DLL has been cancelled" error while trying to erase or program it using Keil uVision IDE.
I am using Keil IDE uVision v5.24.2.0 and a PE Micro Multilink Universal rev b connected via port G - mini-10 for debugger/flashing.
I've looked into some manufacturer's forum and here are some information that might be helpfull:
Operating System: Windows 10
In uVision IDE these are my config:
Flash->Configure Flash Tools...->Debug->Use: PEMicro Debugger->Settings: -Interface: USB Multilink, USB Multilink FX, or Embedded OSJtag -Port: USB1 : Multilink Universal Rev B (PE5655164) -Device: NRF52832-CIAA -Debug Shift Speed = (0) : Multilink = 1.00Mhz, Multilink FX = 25.00Mhz, OSJTAG = 0.25Mhz [checked] Use SWD reduced pin protocol
Is there any configuration i must've done/changed?
on my {Keil_Installation_Folder}\ARM\PEmicro\P&E folder, i got the icdarmcortex_dll_v614.dll and progarmcortex_dll_v614.dll files and also the icdarmcortex_dll_v603.dll and progarmcortex_dll_v599.dll files
Pemicro_ArmCortexInterface.dll is located on my {Keil_Installation_Folder}\ARM\PEmicro folder.
I've downloaded the supportFiles_ARM pack provided by PEMicro website and the Keil_PnE_Support_install_b161130.exe file.
Also tried to flash the module via PROGACMP software, but it stopped answering after an erase attempt.
I don't know where the issue might be, if anyone could help me that would be great.
Thanks in advance,
Bruno.
