Program flashing issue with a bootloader installed
NRF52 pca10028 DK - SDK14 - Arm GCC (Eclipse) - SD 5.0.0 - bootloader_secure_ble
Using either nRFGo Studio or eclipse to program the flash (it does it with both)
I can flash the soft device and the bootloader (in that order) and the bootloader starts fine. If I then program the application, it says it flashed OK but still starts the bootloader (not the application).
I can, however load the same exact program via bluetooth (as a zip package) and it starts fine. I don't have a problem doing that, I am just not sure why it flashes OK over ble (via the bootloader) and not through eclipse or nrfgo studio.
I also tried a mergehex with all 3 files and the bootloader only comes up and not the program.
I can use nrfgo studio to program just the softdevice and application - it works fine, just not with a bootloader installed.
When I compare the sizes and addresses of the SD, BL, and App in nrfgo studio if programmed via nrfgo studio (program does not load) and programmed over ble (program starts), I see no differences - they are identical.
Any help would be appreciated!
Bryan
