Understanding SAADC
Hi all,
I am trying to use the SAADC to measure battery level. I have a rechargable lithium battery connected to my customed PCB with a NRF52832. The rechargable battery has a max voltage of about 4.2V when charged.
I also have a 3.3V voltage regulator connected to the battery and the 3.3V is used to power up the NRF52032.
I am using a voltage divider to measure the battery voltage. 4M ohm to battery and a 10M ohm to ground. The point between the 4M resistor and the 10M resistor is connected to AIN1. There is also a capacitor of 10nF across the 10M resistor.
My saadc init function is as follows:
void saadc_init(void)
    ret_code_t err_code;
    nrf_saadc_channel_config_t channel_config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
    channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
And the callback function is as follows:
      err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer,
      SAMPLES_IN_BUFFER);
  NRF_LOG_INFO("Conversion Result: %d\r\n", p_event->data.done.p_buffer[0]);
      nrf_drv_saadc_uninit();
      NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
      NVIC_ClearPendingIRQ(SAADC_IRQn);
I used a multimeter and measure a voltage if 2.09V at the output of the voltage divider and I am getting a measure value of about 550 for the ADC conversion.
How is this 550 value obtained? And is it the correct value? What is the reference voltage for the ADC? I am assuming it 0.6 x 6 = 3.6V?
If so, then (2.09/3.6) * 1023 = 593. This is slightly off from the measured value of 550.
Can anyone help?
    In your code you are using the nRF52's VDD divided by 4 as reference voltage (NRF_SAADC_REFERENCE_VDD4) and a gain of 1/6. If we rearange the equation presentet here we can see that Vin is:
    Vin = ADCresult * Reference / (Resolution * Gain)
    In your case that should result in:
    Vin = 550 * (VDD/4) / (1024 * (1/6)) = 2.66.
    So something is wrong. Are you sure that VDD is 3.3V?
  • Hi Martin, I don't know the input impedance of my meter.
    Now, instead of measuring the voltage across the 10MOhm resistor, I measured the voltage across the battery instead.
    And these are my observations: Battery Voltage/ADC Value
    • 3.95/592
    • 3.79/568
    • 3.61/541
    There seems to be a consistent pattern. At 3.95V battery voltage, the theoretical voltage at the 10MOhm resistor should be 3.95*(10/14) = 2.821V
    At 3.79V battery voltage, the theoretical voltage at the 10MOhm resistor should be 3.79*(10/14) = 2.707V
    The difference in voltage is 2.832-2.707 = 0.114V and the difference in ADC result is 592-568 = 24. Therefore the ADC resolution is about 0.114/24 = 0.00475
    Working backwards, with a ADC result of 541, this gives a ADC measured voltage of 5410.00475 =2.57V. Take this result and multiple by 2.57(14/10) = 3.598V (battery voltage). Which is quite close to what I measured.
    • 3.95/592
    • 3.79/568
    • 3.61/541
