What are the test images for single bank update?
Hi all,
I want to know if the images inside the hci_dfu_send_hex folder are just precompiled hex files from the examples.
More specific I want to use the bootloader from SDK11 but it doesn't seem that the project example and this test images are the same.
From which project example this images are created? Or if there is any difference between the projects and the test images?
Thank you for the help
Parents Reply
  • I want to make a serial dfu of the bootloader. If I use the bootloader project, I build it and try to load it it give me an error. But if I load the test image of the bootloader there is no error. I am not sure if the test image of the bootloader is suposed to be the image built by the bootloader project.
    If it is not what are the differences? If they are the same do you know what can be causing one to not work and the other is working?
