Missing APP_UART_TX_EMPTY event
Hi!
I am working with an application were two nRF52832 shall communicate over UART in half-duplex 1-wire mode (similar to what is described here but I use different pins for Tx/Rx: devzone.nordicsemi.com/.../). The FIFO version of app_uart (app_uart_fifo.c) and SDK 13.0.0 is used.
APP_UART_TX_EMTY is used to check that data been sent before Tx pin is switched to input mode. The problem I am facing is that I don't get the event if I just use app_uart_put() to transmit single data bytes from unit 1 to unit 2. But if I add printf("\r\n") the event occur as expected. I have verified with oscilloscope that first data byte is sent. Code snippets are shown below.
    void uart_event_handler(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
        else if (p_event->evt_type == APP_UART_TX_EMPTY)
            tx_empty_flag = true;
        else if (p_event->evt_type == APP_UART_DATA_READY)
            data_ready_flag = true;
    while (true)
       while (app_uart_put('A') != NRF_SUCCESS);
       printf("\r\n");  // no APP_UART_TX_EMPTY is received in uart_event_handler if line deleted
       while (tx_empty_flag != true );
       tx_empty_flag = false;
       disable_tx();
Could anyone explain this?
Thanks in advance, Mattias
  • /* I tried this version and it actually works as well */
        enable_tx();
        while (app_uart_put(0x7E) != NRF_SUCCESS);
        while( tx_empty_flag != true );
        disable_tx();
        /* but if I move down disable_tx()like this it does not work */
        enable_tx();
        disable_tx();
    /* So I actually don't need the printf() now, it looks more like a timing issue */
        enable_tx();
        disable_tx();
        enable_tx();
        disable_tx();
