He guys,
I'm currently trying to run the secure serial bootloader sample on our hardware which is based on the nrf52832, but the sample code resets the device when starting to write the application image. See Line 55: 0> <debug> nrf_dfu_settings: nrf_fstorage_write(addr=0x00023000, len=0x80 bytes), queue usage: 1<info> nrf_sdh: Inside main in RTT output.
I use the ble_app_buttonless_dfu_without_bonds_s132.zip sample archive with nrfutil.
Output from RTT Viewer: test.log
Output from Windows PowerShell: PS_output.txt
In order for the sample to run on our hardware I had to modify the following files:
We use different GPIOs for the UART interface and disabled flow control. The UART is connected to a SP3491 (Full-Duplex RS485 Transceiver). Pin 17 and 19 are used as receiver cutput enable and driver output enable and configured via nrf_drv_gpiote in serial_dfu_transport_init.
Am I doing something wrong? Any hints appreciated!
