Diseño de beacon nrf51822- QFAC(DC/DC)
good morning to all I wanted to ask if anyone has a design of nrf51822 where an external temperature sensor is used, to know how the connection to the chip is. Should I buy a sensor with an analog output or a digital output? What is the difference? Is this sensor valid to take the room temperature?Sensor Does anyone know how ADC works? I would also like to know how to implement an antenna, what do I mean by this? I understand that the reference design does not come with the design of the antenna, is this true? If it is correct, how can I implement an antenna for the development of the beacon with nrf51822-QFAC(dc/dc)? Another question is, how is the balun connection for nrf51822? Where does the balun connect, on which pins on the chip? With what software can I edit the PCB, to do the implementation of the antenna, the balun and the temperature sensor? I also need to make the copper island for each pin of the chip, so I have the possibility to program without removing it from the pcb circuit, can it be carried out? I hope I have been clear in the questions. Greetings to all.
  • Hello Jorn Froysa. I thank you immensely for the answer. Let's go in parts: -Thank you for the data of the sensors, I have decided to buy that, and with an analog output.
    • Yes, I am new, I just want to buy everything needed to develop the headlamp, the idea is to make a single order, since the shipping costs are more expensive than the products. -Download the manual and product specifications.
    • Could the nRF52 be the most up-to-date version?
    • Can you develop a headlight in the same way as with nRF51?
    • I ask the antenna question and the balun question, since I will buy the SDK (as long as it is convenient before the nRF52), also buy the beacon kit, 5 chip nRF51822 - QFAC with corresponding components for each . "Is it all necessary?" Or with the SDK and chips with the necessary components is enough? I understand that the SDK can not connect to a smartphone, but the beacon kit does. It is true?
    • As for the balun connection in Figure 35 on page 104 of the product specification, in the packet variation is CDAB WLCSP, is the same connection for QFAC QFN48? regards
  • I have updated my answer above to answer your questions.
