what's the function of the paramter BLE_L2CAP_MTU_DEF?
hello, the function ble_stack_init () in the example of ble_app_uart are quite different from that in the example of ble_app_proximity in my first sight. ble_app_uart :
    // YOUR_JOB: If the MTU size is changed by the application, the MTU_SIZE parameter to
    //           BLE_STACK_HANDLER_INIT() must be changed accordingly.
    BLE_STACK_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM,
                           BLE_L2CAP_MTU_DEF,
                           ble_evt_dispatch,
                           false);
ble_app_proximity :
    uint32_t err_code;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
after comparison, I find the parameter BLE_L2CAP_MTU_DEF may be the point. I get confused the function of the parameter,thought it says Default L2CAP MTU.
what will happen if I change the value of the parameter?
