Save multiple values with FDS
There are a few setting options I would like to keep through power cycle like sensor sampling rate, continuous sampling on/off, etc. I had success implementing saving of one value using FDS with the following functions
static ret_code_t fds_test_write(void)
	#define FILE_ID     0x1111
	#define REC_KEY     0x2222
	fds_record_t        record;
	fds_record_desc_t   record_desc;
	fds_record_chunk_t  record_chunk;
	// Set up data.
	record_chunk.p_data = &timerTick;
	record_chunk.length_words   = 1;
	// Set up record.
	record.file_id              = FILE_ID;
	record.key              		= REC_KEY;
	record.data.p_chunks       = &record_chunk;
	record.data.num_chunks   = 1;
	ret_code_t ret = fds_record_write(&record_desc, &record);
	if (ret != FDS_SUCCESS)
			return ret;
	return NRF_SUCCESS;
  static ret_code_t fds_read(void)
	fds_flash_record_t  flash_record;
	fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
	uint32_t *data;
	uint32_t err_code;
	// Loop until all records with the given key and file ID have been found.
	while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
			err_code = fds_record_open(&record_desc, &flash_record);
			if ( err_code != FDS_SUCCESS)
				return err_code;
			NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
			data = (uint32_t *) flash_record.p_data;
			timerTick = data[0];
			NRF_LOG_INFO("%d\r\n",timerTick);
			// Access the record through the flash_record structure.
			// Close the record when done.
			err_code = fds_record_close(&record_desc);
			if (err_code != FDS_SUCCESS)
				return err_code;
	return NRF_SUCCESS;
Now I'm trying to add a second value to save. The modification in my mind is to change
to
    uint32_t dataToSave[2] = {timerTick, value2};
    record_chunk.p_data = dataToSave;
    record_chunk.length_words = 2;
Before adding the second value, I tried to modify the code to save the value I initially had. In this case, I always got 810000 no matter what number I set timerTick to save.
    uint32_t dataToSave[1] = {timerTick};
Is this the right way to save multiple values with FDS? Why do I always get 810000 instead of the right value?
