Reconfigure of WDT
hi,
i need to reconfigure the WDT and also change the timer value in WDT. is it possible to do that.
i tried but i can not.
1.configured wdt with timer 5sec. 2.i had reconfigued wdt with timer 1 sec.
before reconfigue i have clear the start task(START_TASK=0)
but it still running upto 5 sec
please any one help
  • This works for me (SDK 14.0.0 with s132) ..
    In main.c:
    #define WATCHDOG_SECONDS 5 /**< Time in [seconds] before watchdog resets MCU. */
    /**@brief Function for initializing the watchdog.
     * @details This function will be called in case of the watchdog timer not being reset at the end of the big while
     * @warning This may or may not cause resets on errors when initialized
    void wdt_init(void){
        //Configure Watchdog. a) Pause watchdog while the CPU is halted by the debugger.  b) Keep the watchdog running while the CPU is sleeping.
    	NRF_WDT->CONFIG = (WDT_CONFIG_HALT_Pause << WDT_CONFIG_HALT_Pos) | ( WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
    	NRF_WDT->CRV = WATCHDOG_SECONDS*32768;  // timout limit
    	NRF_WDT->RREN |= WDT_RREN_RR0_Msk;      // Enable reload register 0
    	NRF_WDT->TASKS_START = 1;               // Start the Watchdog timer
    int main(void){
        wdt_init();     //Initialize watchdog
        for(;;){
            // Application stuff
             NRF_WDT->RR[0] = WDT_RR_RR_Reload;  //Reload watchdog register 0
             power_manage();
