In Nordic\nrf51822\Board\pca10001\s110\ble_app_hrs project,the NVIC_EnableIRQ(TIMER2_IRQn)
In Nordic\nrf51822\Board\pca10001\s110\ble_app_hrs project,when I add somting into this project but the now that I add dose not work!!?
//this is buzee_gpiote_init()
static void buzee_gpiote_init(void)
    // Connect GPIO input buffers and configure PWM_OUTPUT_PIN_NUMBER as an output.
    //nrf_gpio_range_cfg_input(BUTTON_START, BUTTON_STOP, BUTTON_PULL);
    nrf_gpio_cfg_output(20);
    nrf_gpio_port_clear(NRF_GPIO_PORT_SELECT_PORT0, 0xFF);
    // Configure GPIOTE channel 0 to toggle the PWM pin state
    // @note Only one GPIOTE task can be connected to an output pin.
    nrf_gpiote_task_config(3, 20, \
                           NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_LOW);
//this is buzee_ppi_init();
static void buzee_ppi_init(void)
    // Configure PPI channel 0 to toggle PWM_OUTPUT_PIN on every TIMER2 COMPARE[0] match.
    NRF_PPI->CH[4].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[0];
    NRF_PPI->CH[4].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[3];
    // Configure PPI channel 1 to toggle PWM_OUTPUT_PIN on every TIMER2 COMPARE[1] match.
    NRF_PPI->CH[5].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[1];
    NRF_PPI->CH[5].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[3];
    // Configure PPI channel 1 to toggle PWM_OUTPUT_PIN on every TIMER2 COMPARE[2] match.
    NRF_PPI->CH[6].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[2];
    NRF_PPI->CH[6].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[3];
    // Enable PPI channels 0-2.
    NRF_PPI->CHEN = (PPI_CHEN_CH4_Enabled << PPI_CHEN_CH4_Pos)
                    | (PPI_CHEN_CH5_Enabled << PPI_CHEN_CH5_Pos)
                    | (PPI_CHEN_CH6_Enabled << PPI_CHEN_CH6_Pos);
//this is buzee_timer2_init();
static void buzee_timer2_init(void)
    // Start 16 MHz crystal oscillator .
    //NRF_CLOCK->EVENTS_HFCLKSTARTED  = 0;
    //NRF_CLOCK->TASKS_HFCLKSTART     = 1;
    // Wait for the external oscillator to start up.
    //while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        //Do nothing.
    NRF_TIMER2->MODE        = TIMER_MODE_MODE_Timer;
    NRF_TIMER2->BITMODE     = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;
    NRF_TIMER2->PRESCALER   = TIMER_PRESCALERS;
    // Clears the timer, sets it to 0.
    NRF_TIMER2->TASKS_CLEAR = 1;
    // Load the initial values to TIMER2 CC registers.
    NRF_TIMER2->CC[0] = MAX_SAMPLE_LEVELS + MAX_SAMPLE_LEVELS;
    NRF_TIMER2->CC[1] = MAX_SAMPLE_LEVELS;
    // CC2 will be set on the first CC1 interrupt.
    NRF_TIMER2->CC[2] = 0;
    // Interrupt setup.
	//NRF_TIMER2->INTENCLR = 0xFFFFFFFF;
    NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
    uint32_t err_code;
    timers_init();
    gpiote_init();
    buttons_init();
	buzee_gpiote_init();
    buzee_ppi_init();
    ble_stack_init();
    bond_manager_init();
    //Initialize Bluetooth Stack parameters
    gap_params_init();
    advertising_init();
    services_init();
    conn_params_init();
    sec_params_init();
    // Start advertising
    advertising_start();
	NVIC_EnableIRQ(TIMER2_IRQn);
    // Enter main loop
    for (;;)
        // Switch to a low power state until an event is available for the application
        err_code = sd_app_evt_wait();
The code like up,but the NVIC_EnableIRQ(TIMER2_IRQn); does not work so I can not get a PWM signal. But if I put NVIC_EnableIRQ(TIMER2_IRQn); before ble_stack_init(); ,I can get a PWM signal but Ble(the radio ) does not work .
I does not kown why,Please! dong Thanks!
