POFWARNING and s132
Hi all,
i'm trying to use the function of power warning with s132 and nrf52 with sdk 11.
i use the function
  err_code = sd_power_pof_threshold_set( NRF_POWER_THRESHOLD_V27);
   err_code = sd_power_pof_enable(POWER_POFCON_POF_Enabled);
but seems that it not set correctly the threshold. I expect that warning occurs when voltage goes under 2,7. But what i can see is that the warning occurs with 2.0 V.
if i try to set the value register "manually" NRF_POWER->POFCON = 0x1D; the softdevice goes in assert.
Can help me?
Anna
    This is probably due to a known bug in S132 v2.0.0 which is fixed in S132 v2.0.1. If you are using v2.0.0 I suggest that you upgrade it. An upgrade between minor version numbers like this causes no breaking API challenges or qualification issues.
