DFU with Android 7.0 fails on connection
Dear Helpers,
We are facing an issue. It is all related to DFU (secure buttonless) and Android 7.0 (deployed on a Samsung A5).
We have a code that is running perfectly that allows advertising / scanning and connection with an nrf52832. I have a series of smartphone with NRF Connect and playing with : connecting to the module, starting DFU (using the service/characteristic command sent) and connecting on the newly "created" DFU target. It works on Android 6.0.1 (LG K8) / Android 5.0.1 (Samsung S4). But on Nougat....
So on Nougat, using NRFConnect (4.13.2), I can :
  • Connect to my module (s132 v3.1, SDK 12.3)
  • Discover services
  • Start the DFU and the module reboots correctly
  • try to connect to DFUTarget... but, the module reboots immediately without any "appearing" reasons. The I have shows the event BLE_GAP_EVT_CONNECTED and then nothing and reboots.
I tried to set (bootloader and DFU compiles and executes) :
ble_opt_t ble_opt;
memset(&ble_opt, 0, sizeof(ble_opt));
ble_opt.gap_opt.compat_mode_2.mode_2_enable = 1;
err_code = sd_ble_opt_set(BLE_GAP_OPT_COMPAT_MODE_2,&ble_opt);
and also :
void data_len_ext_set(void) {
ret_code_t err_code;
ble_opt_t  opt;
memset(&opt, 0x00, sizeof(opt));
opt.gap_opt.ext_len.rxtx_max_pdu_payload_size = 0;
err_code = sd_ble_opt_set(BLE_GAP_OPT_EXT_LEN, &opt);
APP_ERROR_CHECK(err_code);}
without success.
The only relevent debug log comes from the phone and says :
BluetoothRemoteDevices: aclStateChangeCallback: State:DisConnected to Device:XX:XX:XX:XX:XX:XX
BluetoothGatt: onClientConnectionState() - status=8 clientIf=7 device=XX:XX:XX:XX:XX:XX
BluetoothEventManager: onReceive :: android.bluetooth.device.action.ACL_DISCONNECTED
BluetoothEventManager: ACTION_ACL_DISCONNECTED
BluetoothUtils: getBtEnabledContainers(): btContainers = []
PanService: onReceive : android.bluetooth.device.action.ACL_DISCONNECTED
bt_btif : btif_dm_upstreams_cback ev: BTA_DM_BUSY_LEVEL_EVT
bt_btif : BTA_DM_BUSY_LEVEL_EVT :: p_data->busy_level.level_flags : 0x0
EnhancedTetheringManager: isLastConnectedDevice : XX:XX:XX:XX:XX:XX
SapService: Unexpected error!
SamsungAlarmManager: setExact Intent (T:2/F:1/AC:false) 20170913T145244 - CU:10021/CP:4688
SamsungAlarmManager: setLocked to kernel - T:2 / 20170913T145244, SetElapsed=277088718, nowELAPSED=277087734
KnoxKeyguardUpdateMonitor: BroadcastReceiver onReceive
KnoxKeyguardUpdateMonitor: BroadcastReceiver onReceive action: android.bluetooth.device.action.ACL_DISCONNECTED
KnoxKeyguardUpdateMonitor: BroadcastReceiver ACTION_ACL_DISCONNECTED
DfuBaseService: Connection state change error: 8 newState: 0
DfuBaseService: Device got disconnected before service discovery finished
DfuBaseService: Action received: android.bluetooth.device.action.ACL_DISCONNECTED
BluetoothGatt: refresh() - device: XX:XX:XX:XX:XX:XX
BtGatt.GattService: refreshDevice() - address=XX:XX:XX:XX:XX:XX
DfuBaseService: Refreshing result: true
DfuBaseService: Cleaning up...
TrustAgent.Tracker: [BluetoothConnectionTracker] Bluetooth connect broadast for DfuTarg XX:XX:XX:XX:XX:XX
BluetoothGatt: close()
BluetoothGatt: unregisterApp() - mClientIf=7
BtGatt.GattService: unregisterClient() - clientIf=7
TrustAgent.Tracker: [BluetoothConnectionTracker] Bluetooth disconnect broadast for DfuTarg XX:XX:XX:XX:XX:XX
I am struggling on that with Nougat...
Any help would be appreciated.
David
Edit 1 : We have tested on a mobile device that is running Android 7.1.1... And it's working. The mobile is a Motorola.
    The Samsung A-series phone have several bugs with how they do LL control procedures as mentioned in this post.
    But first, let's try to disable the DLE feature completely, and see if that makes any difference:
    Add
    err_code = sd_ble_opt_set(BLE_GAP_OPT_DLE_DISABLE, &opt);
    in the buttom of the data_len_ext_set() function. data_len_ext_set() should then look like this:
        ble_opt_t  opt;
    Add
        ble_opt_t  opt;
