Found on the web:
"Properly configured WiFi network shouldn’t interfere with the Bluetooth signal. The best practice for WiFi configuration is enabling WiFi on one of the following channels: 1, 6, 7, 8, 9, 10, 11, 12. Other channels: 2, 3, 4, 13, 14 might cause interference with Bluetooth signal and it’s best to avoid them. When configuring three different WiFi networks the best solution is to use channels 1, 6 and 11. This helps to avoid the interference with Bluetooth Smart and between themselves."
Given a particular Wifi channel, what should the AFH channel map be set to?
