LED1/2/3/4 are ON
I am running example: nrf5-ble-tutorial-advertising on a nRF52-DK. with SDK 11 and s132_nrf52_2.0.0 softdevice. When I flash the code to the nRF52-DK, LED1, LED2, LED3 and LED4 are ON. My Main.c code is:
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "pstorage.h"
#include "app_trace.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "nrf_gpio.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT  0                                          /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define CENTRAL_LINK_COUNT               0                                          /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT            0                                          /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME                      "ECO"
//**************************************************                            /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                 300                                        /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS       0                                        /**< The advertising timeout in units of seconds. */
#define APP_TIMER_PRESCALER              0                                          /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE          4                                          /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL                MSEC_TO_UNITS(100, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL                MSEC_TO_UNITS(200, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                    0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY    APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT     3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                   1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                   0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                   0                                          /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS               0                                          /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES        BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                    0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE           7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE           16                                         /**< Maximum encryption key size. */
#define DEAD_BEEF                        0xDEADBEEF                                 /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
static dm_application_instance_t         m_app_handle;                              /**< Application identifier allocated by device manager */
static uint16_t                          m_conn_handle = BLE_CONN_HANDLE_INVALID;   /**< Handle of the current connection. */
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
    // Declearing parameter structs. Try to go to the struct definitions to get
	// more information about what parameters they contain
    ble_gap_conn_params_t   gap_conn_params; 	// Struct to store GAP connection parameters like max min connection interval etc
    ble_gap_conn_sec_mode_t sec_mode;			// Struct to store security parameters
    // A simple macro that sets the Security Mode and Level bits in sec_mode
	// to require no protection (open link)
    // Store the device name and security mode in the SoftDevice. Our name is defined to "HelloWorld" in the beginning of this file
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    APP_ERROR_CHECK(err_code); // Check for errors
    // Always initialize all fields in structs to zero or you might get unexpected behaviour
    // Populate the GAP connection parameter struct
    // Set GAP Peripheral Preferred Connection Parameters
    // The device use these prefered values when negotiating connection terms with another device
    // Set appearence
	sd_ble_gap_appearance_set(0);
	APP_ERROR_CHECK(err_code);// Check for errors
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for handling the Application's BLE Stack events.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            // No implementation needed.
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the BLE Stack event interrupt handler after a BLE stack
 *          event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    dm_ble_evt_handler(p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
/**@brief Function for handling the Device Manager events.
 * @param[in] p_evt  Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
                                           dm_event_t const  * p_event,
                                           ret_code_t        event_result)
    APP_ERROR_CHECK(event_result);
#ifdef BLE_DFU_APP_SUPPORT
    if (p_event->event_id == DM_EVT_LINK_SECURED)
        app_context_load(p_handle);
#endif // BLE_DFU_APP_SUPPORT
    return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
    register_param.sec_param.bond         = SEC_PARAM_BOND;
    register_param.sec_param.mitm         = SEC_PARAM_MITM;
    register_param.sec_param.lesc         = SEC_PARAM_LESC;
    register_param.sec_param.keypress     = SEC_PARAM_KEYPRESS;
    register_param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    register_param.sec_param.oob          = SEC_PARAM_OOB;
    register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    uint32_t      err_code;
    ble_advdata_t advdata;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for the Power manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Function for application main entry.
    uint32_t err_code;
    bool erase_bonds;
    // Initialize.
    timers_init();
    ble_stack_init();
    device_manager_init(erase_bonds);
    gap_params_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
        power_manage();
