Changing the default Channel Map with sd_ble_opt_set
We're designing a product with the nRF52 (SoftDevice S132 v5.0.0 production) and an external WiFi module, and are attempting to do a "poor man's WiFi Co-Existence" by disabling all BLE channels that overlap with the known WiFi channel.
It appears that we are able to successfully set the Channel Map like so for WiFi Channel 1 (no errors are returned):
static uint8_t m_ch_mask[CHANNEL_MAP_BYTE_CNT] = {0x00, 0xfe, 0xff, 0xff, 0x1f};  //disable BLE channels overlapping with WiFi Channel 1
ble_gap_opt_ch_map_t channel_map = {0};
channel_map.conn_handle = conn_handle;  //we get conn_handle on a CONNECT event
memcpy(channel_map.ch_map, m_ch_mask, sizeof(m_ch_mask));
ret_code_t err_code = sd_ble_opt_set(BLE_GAP_OPT_CH_MAP, (ble_opt_t *)&channel_map);
if (err_code != NRF_SUCCESS) {
    LOG(LOG_LEVEL_ERROR, "failed to set channel map: %d\r\n", err_code);
    return -1;
However, when reading back the Channel Map using sd_ble_opt_get, we still see the default channel map: ff ff ff ff 1fwhen connecting from a laptop. When connecting using the nRF Connect app, we see something other than the default channel map; however, some of the bits set to 0 in the mask during sd_ble_opt_set are set to 1 when reading it back with sd_ble_opt_get.
I did read a couple of other related posts on the DevZone:
How to Change Channel Map for exchanging DaTa ?
How to correctly set channel map of next connection?
However, even waiting minutes after the connection is made, we still see bits set to 1 with sd_ble_opt_getthat were set to 0 in sd_ble_opt_set.
Is there anything we're missing? Is this functionality being used successfully by anyone with S132 v5.0.0?
